587,726 active members*
3,451 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC Machining Centres > 5 Axis CNC- toolpath not working right
Results 1 to 2 of 2
Threaded View
    May 2021
    2
    I have generated a 5-axis toolpath for a simple model using Powermill 2020. After I export the g-code and load it onto the machine, it does not work properly. The exact issue is that the machine is not milling according to the material block. It is going outside the block and the coordinates do not match the simulation in Powermill.
    When I export the code, Powermill shows me an error saying “ the machine tool in Powermill and the machine tool in option file differ “. Can this be the issue for the coordinates not exporting properly?
    Attached Thumbnails Attached Thumbnails 5 axis CNC_ Setup.jpg   Control software settings.jpg   export error_Powermill.jpg
