587,098 active members*
5,610 visitors online*
Results 1 to 2 of 2
    Apr 2011
    31
    Torq Cut T3g Transmission
    Hello,
    Our transmission is leaking oil. Before I blindly start unbolting everything, what kind of job is it getting this off and fixing it? I assume it needs a new seal, but won't really know until the baby is in the crib, or table top.
    Thank you.
    Dec 2009
    521
    Re: Torq Cut T3g Transmission
    Quote Originally Posted by scrap maker View Post
    Hello,
    Thank you.
    I hope someone that has been there done that responds. I may have to do this myself, if I have to rebuild the transmission.
    Where is the seal that is leaking? Output shaft?
    Marty
  1. Spindle play torq cut 22 with transmission
    By cooperjm in forum Bridgeport / Hardinge Mills
    Last Post: 07-27-2019, 02:33 PM
  2. Torq Cut 22 Transmission oil
    By hax0red in forum Bridgeport / Hardinge Mills
    Last Post: 01-03-2017, 03:25 PM
  3. Bridgeport Torq-cut transmission speed?
    By Dragonwrath-I in forum Bridgeport / Hardinge Mills
    Last Post: 07-28-2016, 05:51 PM
  4. Torq-Cut 22 Transmission Gear Change Rotary Actuator
    By cncone in forum Bridgeport / Hardinge Mills
    Last Post: 03-27-2014, 07:22 PM
  5. torq cut 30 transmission ?
    By porkchop21 in forum Bridgeport / Hardinge Mills
    Last Post: 02-04-2013, 02:49 PM
