587,481 active members*
2,793 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Okuma Genos M560 - Help, Can't get spindle to run, what am i doing wrong????
Results 1 to 11 of 11
    Nov 2003
    299
    Hey Guys,
    I'm sure I'm doing something stupid. I just got this Okuma Genos M560 and I'm not that familiar with the control.
    The problem is I've been unsuccessful at getting the spindle to run. The machine is lightly used and has been sitting in storage for a year. I saw it running when I bought it just before putting it in storage. I just got the machine brought into my shop from storage a few weeks ago and have been playing around trying to figure out the control. I can jog all the axis, command G30P1 and it moves all axis to home, can turn blow air on/off, etc. , but when I command S500M3 I get no spindle movement and no alarms. The icon in the top left corner of screen flashes yellow as if the machine is doing something but the spindle don't rotate at all. Can't get it to spin up using the manual buttons or the spindle orientation.
    If I put the machine into machine lock and do the S500M3 it shows the spindle turning CW (on screen) like it should.
    I checked the ATC operation and it's at Seq 1. And I do have a tool loaded in the spindle.
    OK, what am I doing wrong??
    Apr 2009
    1262
    Re: Okuma Genos M560 - Help, Can't get spindle to run, what am i doing wrong????
    Do you have the tool clamp and door closed signals? Are you using the correct pull stud?
    Experience is what you get just after you needed it.
    Feb 2005
    69
    Do you have the tool you are calling up registered in the tool data page?
    Nov 2003
    299
    Quote Originally Posted by OkumaWiz View Post
    I get a green light next to the tool clamp button on the spindle. When can i look for the door closed signal?
    The tooling is from previous owner so pull stud should be ok.
    Nov 2003
    299
    Quote Originally Posted by Factory Guy View Post
    The previous owner removed all the physical tools from the magazine but left them in the control. So, I detached all the tools in the magazine. I tried to detach the tool in the spindle but the control gave me an error. "Cannot detach active tool" i think it said. So it still shows a tool "tool # 150" in the spindle. Next tool is "NONE".
    I tried to do a toolchange G111, it got to about seq13 and errored out due to not being able to orient the spindle. Went into machine operation and backed out the toolchange.
    Nov 2003
    299
    What conditions will prevent the spindle from running?
    Feb 2005
    69
    It's usually a limit switch, tool clamped, no tool exist, unclamp switch etc. When you hit cycle start for the spindle in MDI mode is there any alarm? Try hitting display change and page down to Machine Diagnostic. That might help describe what is going on.
    Nov 2003
    299
    No alarm. Just sits there with the machine status flashing yellow. I'm not at the machine right now but I'll look for the diagnostic page later tonight. Thank you very much for the help.
    Jun 2015
    4156
    hi, it may be possible that your spindle can not reference it's zero position
    at least for lathes, this is a must / kindly
    Ladyhawke - My Delirium, https://www.youtube.com/watch?v=X_bFO1SNRZg
    Nov 2003
    299
    Relief!!!
    Got it figured out...
    Found that Diagnostics page Factory Guy mentioned. That helped. Seems the clamp signal was not on when the tool was in spindle. Most likely from dried oil? in the taper or pull stud area from the machine sitting in storage. Cleaned all that out and worked the clamp/unclamp mechanism several times and now I can get the spindle to run. As a side note to someone troubleshooting this kinda thing, i also noticed the time the hydraulic unit runs when clamping the tool was much longer before when it wasn't working correctly and now it only runs a couple seconds to clamp. The other thing I noticed is the orange light on the tool change button was staying lit before. Now the light goes off after one cycle.
    Thank You everyone for the help. Much Appreciated
    Jun 2015
    4156
    hi, on some models, if the hydraulic is running too much, then a safety switch raises inside the electrical cabinet, so to avoid burning the pump
    if your machine would behave the same, than it may make you wonder why the switch is moving; maybe, on your model, you simply have a timer ? however, there should be an error about hidraulic time-out
    i mean that it is a bit weird, i also had encountered a similar problem, but the machine was showing an alarm
    about dried oil, i like to work clean, and, from time to time, i remove all tools from the atc, clean the pots and tool tapers, spindle taper, etc / kindly
  1. Okuma post for M560-V OSP 300
    By mavrich in forum PowerMILL
    Last Post: 07-31-2019, 02:01 PM
  2. OKUMA GENOS M560 POST. PROBLEM
    By mavrich in forum Okuma
    Last Post: 08-21-2017, 01:19 PM
  3. Replies: 4
    Last Post: 03-01-2014, 08:47 PM
  4. OKUMA Genos M560
    By karkudata in forum Okuma
    Last Post: 08-28-2013, 10:38 PM
  5. Anyone Have A Okuma Genos m560-v
    By Mountainwildman in forum Okuma
    Last Post: 01-14-2011, 06:49 AM
