587,506 active members*
3,075 visitors online*
Results 1 to 4 of 4
    Aug 2011
    999
    Furniture Grade Cable Chain
    Another wacky idea, originally intended for a special furniture project (that I did not finish...). But I think it will find a use sometimes.
    This is a cable chain and normally I would use the proven IGUS cable carriers that are available for little money on eBay. But I wanted to make it prettier and living room compatible.
    The elements of this chain are cut from 3/4" marbled walnut (120-deg v-bit for the chamfer, 1/2" ballnose for the bead seats, 1/8" end mill for the holes and cutout and pair-wise glued together. Then sanded and laquered. Then strung up onto two 1/16" steel ropes with 1/2" wood beads as swiveling joints. The steel rope is held taut by two springs.
    Machining the 50 elements (all done with my BigBamboo machine, see build log here):
    Glued together to make 25 links and 2 end pieces. Also 50 wood beads, all laquered and/or waxed
    Starting the string-up:
    Chain finished:
    Short video clip:
    Box Joint and Dovetail CAM software here: WWW.TAILMAKER.NET
    Dec 2013
    5716
    Re: Furniture Grade Cable Chain
    Wow, that's a nice looking chain. :cheers:
    Jim Dawson
    Sandy, Oregon, USA
    Dec 2014
    640
    Nice!!!
    Feb 2016
    286
    "Living room compatible" is a masterpiece of an understatement!
    Nice work!
  1. Looking for cable chain
    By neurofen in forum DIY CNC Router Table Machines
    Last Post: 02-19-2014, 02:03 AM
  2. Cable Chain
    By GAWnCA in forum Mechanical Calculations/Engineering Design
    Last Post: 11-15-2012, 05:35 PM
  3. Cable Chain noe from Misumi
    By Al_The_Man in forum Work Fixtures / Hold-Down Solutions
    Last Post: 07-12-2012, 03:50 PM
