587,396 active members*
3,880 visitors online*
Page 1 of 3 123
Results 1 to 20 of 52
    Aug 2006
    119
    Rotary Encoders
    Hi I have 4 rotary encoders i need to start a project with these I'm thinking
    Digital Readout for my metal lathe... but i need some help... i have technical documents, but i don't know were to start, any help is appreciated
    thank you
    Frank
    Jun 2003
    866
    tell us more, you have encoders but no display/counter? There used to be someone who sold encoder counters for some of the Chinese encoders, but I don't remember the name right now. You could change those counters to work with normal quadrature encoders if I'm remembering correctly.
    Dec 2003
    24223
    If these are incremental quad encoders see this link for a diy DRO.
    http://www.lindsayengraving.com/othe...rests/dro.html
    Al.
    Albert E.
    Mar 2004
    1806
    I still have the sofware up on my website (updated) for the lindsey dro that uses a dos based computer to interupt and display the values.
    http://bellsouthpwp.net/A/r/Arts_home_page/DRO/
    It might also give you some ideas of the trials and tribulations of the setup.
    Bubba
    Art
    AKA Country Bubba (Older Than Dirt)
    Aug 2006
    119
    DRO's
    Hi ...this information you guys provided reminds me why im addicted to this website thanks to all of you..... here is technical data for the encoders i have to do more research on the spects
    Frank
    Attached Thumbnails Attached Thumbnails ROD_500_Page_01.jpg   ROD_500_Page_07.jpg
    Dec 2003
    24223
    As you can see from the specs, be aware that Heidenhain can be 5v square wave or low signal sinewave. The Sine wave require a less common interface type.
    Al.
    Albert E.
    Aug 2006
    119
    Dro
    Hi AL thanks for the help....I have a limited knowledge of electronics but i think i can pull this one off with a little help.. i don't understand what the difference is between 5v square wave and low signal sine wave. here is the pictures of the encoder wiring.I'm not sure how to wire it with the hard ware setup Giff below i also have an encoder interface i dont know what it is or if its usefully.
    I'm hoping the transistors i bought at radio shack will work spects are below
    Frank
    Attached Thumbnails Attached Thumbnails New Image.GIF   Untitled-1 copy.jpg   encoder 1.jpg   encodre 2.JPG
    Dec 2003
    24223
    What is the part number of the encoder? I can tell you what the output is if you are in doubt.
    You will need different interface logic for each type.
    Al.
    Albert E.
    Aug 2006
    119
    Rod
    Id Nr. 406 008 15
    S. Nr 15903
    Dec 2003
    24223
    what is the ROD/RON# ?
    Al.
    Albert E.
    Aug 2006
    119
    Dro
    Sorry al Rod 523 /1003 09000
    Frank
    Dec 2003
    24223
    Your in luck they are 5v TTL.
    I guess you figured that out from the sheet you posted.
    Al.
    Albert E.
    Aug 2006
    119
    Dro
    HI Al i have no clue how to wire this encoder their are 12 wires on this encoder cable i don't know witch on is for CHB...5V...CHA...GND
    Frank
    Dec 2003
    24223
    The DIY DRO that you are interested in, only uses the 5v and common and the A & B signal, so this is only four conections from the encoder.
    Some have a connector and some are hardwired, I will list both.
    The ROD 525 connections you want are:
    D or Brown/Green = +5v
    F or White/Green = 5v common
    A or Brown = A Pulse
    B or Grey = B pulse
    The rest, tape up.
    Al.
    Albert E.
    Aug 2006
    119
    Dro
    Al you are the man how did you find this information iv been looking for weeks
    Dec 2003
    24223
    Quote Originally Posted by frankg521 View Post
    I had a habit of amassing manuf. cat. etc back when they used to publish and send them out to users.
    It has turned out very usefull when looking at older/legacy items on ebay, etc.
    Actually, Heidenhain is one of the few that is very good at getting information by emailing them in a pinch.
    Al.
    Albert E.
    Aug 2006
    119
    Dro
    Thats great Al ....I'm going to wire it right now ...could you sent me the docs they sent you?? [email protected] thank you very much
    Frank Gorman
    Dec 2003
    24223
    Here is a couple of relevant PDF pages.
    Al.
    Attached Files Attached Files
    Albert E.
    Aug 2006
    119
    Dro
    HI al
    I wired 1 axis for testing but no joy i double checked all connections i have 5 volts at the encoder how do i diagnose this circuit
    Frank
    Aug 2006
    119
    Dro
    I have windows 2000 on a dell laptop could that be the problem
Page 1 of 3 123
  1. Where to buy rotary encoders on Oz?
    By Splint in forum Australia, New Zealand Club House
    Last Post: 04-25-2007, 08:19 AM
  2. rotary encoders...worth it?
    By gearsoup in forum Mechanical Calculations/Engineering Design
    Last Post: 02-27-2006, 08:59 AM
  3. Sources for Rotary Encoders
    By ViperTX in forum Servo Motors / Drives
    Last Post: 03-15-2005, 10:31 PM
  4. Encoders !!
    By Auzze in forum CNC Machine Related Electronics
    Last Post: 07-26-2004, 01:06 PM
