587,672 active members*
5,046 visitors online*
Results 1 to 4 of 4
    Aug 2014
    3
    SolidCAM and tapping adaptor
    Hi all,
    I need to use tapping adaptor with interchangeable ends for various tap sizes and was wondering how to specify it in SolidCAM. The problem is that it is one tool taking one space in a magazine but it has interchangeable ends so it's like a number of tools in one tool slot. Is there any way to specify it in SolidCAM; i.e. tap size, length and thread pitch for every individual end?
    Thanks in advance for your help.
    May 2013
    37
    Re: SolidCAM and tapping adaptor
    You can set up new operations offset another number. but you can not change the pitch of the thread.
    Attachment 315848
    You can add this feature to your postprocessor. Just say what version you're using an SC
    Attachment 315850
    Aug 2014
    3
    Hi partur, I'm using SC 2014. How can I program it in the post-processor? I want to use M3, M4, M5, M6 and M8 taps.
    May 2013
    37
    This is just an example and may not work with your file gpp. I do not see your postprocessor so I can not give you confidence that it will work with your file Gpp.
    Attachment 316058
    Attachment 316060
    Attachment 316062
  1. chuck adaptor
    By rmcgraw351 in forum Bridgeport / Romi Lathes
    Last Post: 09-28-2011, 02:25 PM
  2. USB adaptor pinout
    By fomaz in forum CNC Machine Related Electronics
    Last Post: 05-25-2011, 07:09 AM
  3. MT4 to R8 adaptor?
    By zzambucca in forum Benchtop Machines
    Last Post: 03-05-2011, 11:15 PM
  4. MT2 to R-8 adaptor
    By BarneyW in forum Bridgeport / Hardinge Mills
    Last Post: 12-28-2007, 05:40 PM
  5. Where to find spindle adaptor ?
    By Roy Norris in forum Uncategorised MetalWorking Machines
    Last Post: 07-30-2005, 04:32 AM
