587,518 active members*
3,627 visitors online*
Thread: Need a VFD
Results 1 to 4 of 4
    Mar 2008
    377
    Need a VFD
    Maybe someone can guide me it the right direction I am looking into purchasing a VFD for my would lathe
    7.5 hp I am trying to set it up so it can run on single face.
    Any help would be greatly appreciated.
    Dec 2003
    24220
    Re: Need a VFD
    You would need to find a manuf. that makes a 7hp 1ph unit, often the limit is around 5hp.
    Check out Hitachi models.
    Al.
    Albert E.
    Mar 2008
    377
    Re: Need a VFD
    Thanks for the reply
    The motor is already install in the lathe so I don't want to pun a knew one I want to be able to change the speed through a controller plus I figure it woul be less noisier installing a VFD instead of a rotory phase convertor.
    Any advice of where I can get one
    Thanks again
    Feb 2015
    74
    Re: Need a VFD
    Quote Originally Posted by cob View Post
    Thanks again
    Sure you can get them from Dan Foss, or WW Grainger, also WEG makes them too
