587,101 active members*
4,601 visitors online*
IndustryArena Forum > MetalWorking > Bending, Forging, Extrusion... > Need to bend 1/2 inch sched 40 aluminium
Results 1 to 2 of 2
    Mar 2005
    140
    I need to bend 40 pieces of 1/2 inch, sched 40 aluminium. Outside diameter is 0.84 (or somethign like that). I only need to bend 40 pieces si I'd like to avoid buying a $600 bender if i can.
    Any ideas?
    Nov 2006
    251
    The material your trying to bend is it solid bar or tube or extrusion.
  1. bend and cut in one motion fixture
    By sc6chuck9 in forum Mechanical Calculations/Engineering Design
    Last Post: 03-01-2007, 02:42 AM
  2. Looking for someone to bend parts!
    By CoolhandLuke in forum Bending, Forging, Extrusion...
    Last Post: 02-21-2007, 04:03 AM
  3. K Values And Bend Radii
    By lostbaka in forum Bending, Forging, Extrusion...
    Last Post: 12-04-2006, 01:29 PM
  4. Bend-Tech-ez
    By diarmaid in forum Mechanical Calculations/Engineering Design
    Last Post: 09-23-2006, 05:19 PM
  5. turns per inch vs threads per inch
    By pminmo in forum DIY CNC Router Table Machines
    Last Post: 08-18-2004, 03:27 PM
