587,892 active members*
3,590 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > PlasmaCam > PLASMACAM: Verions of Windows supported
Results 1 to 2 of 2
    Dec 2016
    6
    Hi friends,
    Can you let me know the latest versions of Windows which you guys are using to run PLASMACAM. I was using in Windows XP. Now want to upgrade my PC.
    Regards
    Sep 2014
    112
    Re: PLASMACAM: Verions of Windows supported
    If you have the newer design edge software, then you can use any windows version including windows 10. The if running the outdated 3.11 version, I know xp works fine. I am not sure about any of the subsequent widow versions on the older software.
    I would call plasmacam's tech team if you are running 3.11, and they can most certainly help you out on this one.
  1. Replies: 14
    Last Post: 08-07-2016, 02:09 AM
  2. DIY supported rail
    By eurikain in forum DIY CNC Router Table Machines
    Last Post: 08-07-2015, 01:08 PM
  3. V9 Not supported.
    By TheBigJW in forum Mastercam
    Last Post: 01-21-2011, 03:07 AM
  4. G1 with R - not supported?
    By padobranac in forum NCPlot G-Code editor / backplotter
    Last Post: 10-13-2008, 06:35 PM
  5. Windows XP or Windows 2000 better with Mach2
    By Beezer in forum Mach Software (ArtSoft software)
    Last Post: 10-18-2004, 04:08 PM
