587,083 active members*
2,675 visitors online*
Results 1 to 6 of 6
    Jul 2014
    6
    Cooling Fans...AC or DC?
    Inside the driver enclosure. Is it worth it to install another power supply to feed fans or do you just run them off of AC mains?
    Dec 2003
    24223
    Re: Cooling Fans...AC or DC?
    I have used both, but if it calls for an extra supply I use the AC mains type.
    Al.
    Albert E.
    Jul 2014
    6
    Thanks Al. Just trying to limit the amount of AC components in the enclosure. However I did read that fans are pretty quiet from an interference standpoint.
    Dec 2003
    24223
    The typical Muffin fan is quiet, if the environment is dusty etc, it pays to positive pressure the enclosure by placing an outside filter on a fan bringing air into the enclosure. Some kind of small exit is required.
    Al.
    Albert E.
    Dec 2013
    41
    I don't mean to highjack this thread, but I'm about ready to cut my controller box for my fans. Al, so if I have one fan pushing air in the case, does another need to be pushing air out or just any exit hole will do? Thanks!
    Dec 2003
    24223
    Any means of exit works, I have fitted a small grill in some cases, the small type that is used with PC fans.
    Al.
    Albert E.
  1. Replies: 0
    Last Post: 06-02-2014, 07:24 PM
  2. Spindle cooling with PC Liquid cooling system
    By enforcer in forum DIY CNC Router Table Machines
    Last Post: 02-07-2012, 09:02 PM
  3. Replacing rear cooling fans on older Haas VF-0
    By lkenney in forum Haas Mills
    Last Post: 12-20-2008, 05:39 AM
  4. fans
    By grahamshere in forum Xylotex
    Last Post: 09-15-2008, 02:32 AM
  5. CNC machined cooling fans
    By mroy0404 in forum Hobby Discussion
    Last Post: 05-20-2007, 03:06 AM
