587,547 active members*
3,251 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Need 3 Wire Measuring Formula for Metric Trapezoidal Threads
Results 1 to 2 of 2
    Jan 2007
    243
    Hello all,
    does anyone out there now where I can get the formula for measuring Metric 30° Trapezoidal Threads using the 3 wire method? I have been able to find the "Best Wire" formula but nothing else.
    Thanks for any help you can give.
    Mar 2008
    240
    Re: Need 3 Wire Measuring Formula for Metric Trapezoidal Threads
    You need a DIN 103 / ISO 2901, 02, 03, 04-1977 in English. I don't think there is a 3-wire measurement available. You may also need to know the required tolerance field.
    Anything in your (new) MH?
    Some help here: Trapezoidal Coarse Thread DIN 103
    At least you will have the bolt dia (inner dia).
  1. Metric threads
    By kaminc in forum Community Club House
    Last Post: 08-13-2013, 07:12 PM
  2. Metric Series Threads.
    By Larry1958 in forum Mechanical Calculations/Engineering Design
    Last Post: 08-15-2012, 05:20 PM
  3. metric threads with ez-path 1
    By rmcgraw351 in forum Bridgeport / Romi Lathes
    Last Post: 11-05-2011, 02:40 PM
  4. Rigid Tapping Metric Threads
    By GM81 in forum Fadal
    Last Post: 07-16-2009, 12:37 PM
  5. Metric Threads
    By jackson in forum MetalWork Discussion
    Last Post: 08-16-2007, 02:10 PM
