587,534 active members*
3,610 visitors online*
Results 1 to 5 of 5
    Apr 2012
    3
    CNC software for dummies
    Hey guys,
    Im new to the CNC world. I have setup a sherline cnc mill already and it is functional. However i need a CAD software that is really easy to use. I mean simple click...click... and machine. Can anyone recommend something that is user friendly.
    Apr 2004
    5749
    Re: CNC software for dummies
    I don't think any of it is quite that simple. You need to find a CAD program that will allow you to create the models you want. Then you need a CAM program that can translate that model into toolpaths for a specific machine, using a particular tool stepping over at whatever distance you choose between passes, and cutting at certain feeds and speeds. Then you need to set up your mill so that it knows where it is in space, load the G-code, and run it.
    Andrew Werby
    Website
    Apr 2014
    16
    I found ArtCam Express to be a fairly easy learning curve. Lots of instructional videos available. You can get a demo and try it for free. BobCad is also good (more geared towards metalworking).
    Quote Originally Posted by dynamic330ci View Post
    Hey guys,
    Sep 2009
    1856
    vectric cut2D
    http://danielscnc.webs.com/
    being disabled is not a hindrance it gives you attitude
    [SIGPIC][/SIGPIC]
    It doesn't work that way, research CAM carefully, you will need to select geometry and choose how it is to be machined.
    Watching the online tutorial videos for a package will give you an idea what's involved, if it was as simple as "click...click... and machine" there would be no market for training courses ;-)
    - Nick
  1. CAD for dummies ?
    By lin842 in forum Uncategorised CAD Discussion
    Last Post: 01-13-2014, 01:34 PM
  2. DNC for dummies
    By Dukerc51 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-04-2011, 01:27 AM
  3. CNC for dummies
    By 300magnum in forum Benchtop Machines
    Last Post: 02-11-2008, 06:54 PM
  4. pwm for dummies
    By Mcgyver in forum CNC Machine Related Electronics
    Last Post: 04-19-2005, 04:08 AM
  5. CNC for dummies
    By Jan-Roger in forum DIY CNC Router Table Machines
    Last Post: 11-27-2004, 10:48 PM
