587,822 active members*
3,038 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > FUSE MONITOR. NIFTY, doubles as Power On indicator. WORKS ANY VOLTAGE AC/DC
Results 1 to 2 of 2
    Feb 2011
    21
    After chasing my tail several times, only to find out one of my many fuses
    had blown, I designed a Clever FUSE MONITOR, I use on each of my 4 axis.
    USES ONLY LEDS (and a resistor) and will work at ANY VOLTAGE AC OR DC!
    Both FRONT PANEL and remote at the fuse LED indicators. Tell in an instant
    if an axis fuse has blown.
    -Front panel uses dual color (RED/GREEN) 3 lead LED.
    -REMOTE FUSE location uses a simple RED LED.
    -Only other component is a resistor.
    -Option diode allows use with AC (provides reverse voltage isolation, lacking in LEDs)
    -Cable is PWR, GND and 1 wire per axis routed from front panel to fuse/distribution block.
    -Value of resistor matches the power supply voltage, I use 1K Ohm for 35VDC.
    -GREEN LEDs doubles as power on indicator, or if NO LED is lite, then master fuse blown.
    -Can use with ANY circuit, not just CNCs.
    See attached Front panel, fuse block, and single and a 4 axis/fuse circuit.
    Shown with X axis fuse BLOWN. Note: 1 RED LED and 3 green on front panel
    NOTE: LITE RED LED beside X fuse.
    GORT
    Attached Thumbnails Attached Thumbnails IMG_2725.JPG   IMG_2728.jpg   Single_axis.jpg   Multiple_axis.jpg
    Sep 2010
    1765
    Nice panel and nice idea Gort! well done! Thanks for sharing!
    PS: you probably can leave off the extra series diode - I have been running 10 cent LEDs on 120 & 240 ac lines with just drop resistor for years.
  1. CRT to LCD conversion, works but monitor blanks for few seconds when spindle on!
    By Spencertech in forum Uncategorised CAM Discussion
    Last Post: 03-31-2013, 06:00 AM
  2. Motor nameplate voltage vs. what works
    By oneartisan in forum Stepper Motors / Drives
    Last Post: 06-30-2010, 11:00 PM
  3. VMC 4020 monitor blowing fuse
    By cncman-818 in forum Fadal
    Last Post: 06-06-2010, 01:16 PM
  4. Can I fuse a DC power supply?
    By Brenck in forum CNC Machine Related Electronics
    Last Post: 11-18-2009, 03:55 PM
  5. Breakout board - power light indicator?
    By MakotoKamui in forum Automation Technology Products
    Last Post: 03-24-2008, 05:45 PM
