587,098 active members*
5,610 visitors online*
Results 1 to 13 of 13
    Mar 2010
    47
    Axis Loosing Sync
    I run a rack & pinion setup and use CandCNC Electronics. My Y Axis uses two motors which are slaved. Motor tuning and steps have been set up equally on both motors.
    I use it as a plasma cutter and do routing work as well with it. I am really happy with it but encountered a problem.
    When I do a pattern with a lot of holes and a lot of different movements the machine starts running wrong and losing it's correct positioning.
    Meaning for example, that the cuts for the outlines (cut after the holes) are 1 or 2 inches from where it should be.
    When I then "Home" the two axis - the one side "arrives" a little later than the other.
    Has somebody experienced something like this and could lead me in the right direction how to fix it?
    Mar 2010
    47
    Isn't there anyone how could help?
    I have been thinking what I think it could be..
    I soldered new wire on the Y Motors because the original ones from CandCNC were too short. Coulod that cause that maybe the resistance sometimes is too high and cause problems?
    Jan 2013
    76
    Is this a new build and done this from the beginning or did it work correctly and now starts to exhibit this problem?
    Mar 2010
    47
    Moin Schwarzwald
    I built the machine myself and the strange thing is that contour cuts run perfectly. It seems that only doing a lot of holes (or having a lot of quick back and forth movements) it seems to cause this problem..
    Jun 2011
    25
    You might want to check the motor configurations. steppers will stall if the acceleration or speed is set too high. If the stepper cannot supply enough torque, it will manifest itself in this behavior.
    Another thing to consider is backlash. You mentioned the back and forth movement which could indicate an accumulation of translational error introduce by excessive backlash.
    Jan 2013
    76
    The thing I would check would be the pinion gears on the shaft to make sure they are really fixed and not slipping back and forth on one motor. Just a small rotation on the shaft will give you something like this maybe.
    Nov 2007
    250
    I'd follow Cheeta's lead on the problem. Sounds like you are loosing steps for one reason or another. You mentioned that the steps per in/mm are the same for both motors, make sure that the acceleration and rapids are the same in the motor set up... I'd make a change even if they are. Slow things down 25%.
    If you are loosing steps because the motors are over taxed, slowing the movement down will help the problem.
    Backlash may come into play if one side has a larger amount of backlash than the other causing the gantry to get out of square... I wouldn't think it would stack up and cause the gear rack to jump a tooth... The gantry would only be out the amount of the backlash and not progressively get worse.
    stay in touch.
    aj
    Nov 2009
    159
    Thats the one problem with steppers is that you can send them instructions and if the resistance to movment is too great they loose a step. A well engineered system will not loose steps. If he is getting good holes he doesnt have mecanical backlash. But he isnt giving all the info needed to make a consideration. What is the weight of the gantry and what are your tuning numbers?
    Now featuring Plasmaland online
    Mar 2010
    47
    Hey thank all of you guys so much for your input. I got engaged and have been out of the Country for many weeks.
    I now had time to take care of some things. Here are my specs for the machine. I am running the 620oz Dragoncut Motors. My Gantry weight is precisely 150 Pounds.
    The Speed I set in the Motor Tuning is: Speed 6000mm/min (236 In/min) and Acceleration 1200 mm/s2 (47 in/s2)
    Is that an ok set up?
    Nov 2007
    250
    I'd like to look at the graph in mach but need all the info. What is the steps per....?? It takes all three variables to take a look at where you're at...
    Aj
    Nov 2012
    64
    If it helps this is what I have mine set at, same motors, 3.75:1 reduction, gantry weight maybe a little less than that.
    Touchwood it's going very well so far, thanks to AJ keeping me on the right track
    Attachment 188418
    Jul 2005
    2415
    Quote Originally Posted by AndiKid View Post
    Well everything is a little on the high side. The gantry weight is about 50 lbs over what we suggest for those motors with a 3:1 belt reduction to a 1" pinion.
    The acceleration is a function of the linear force (derived through pinion from rotary torque) divided by the MASS (weight /32) of the load. There are also frictional forces but are not as big in the equation. If the steeppers have to supply more torque than they can (steppers are torque limited) they simply stall.
    Back all of your acceleration off by 50%. Than see if there is anything you can do to lighten the weight of the gantry. If the table cuts okay on slower cuts or longer contours it is not an electronics or mechanical issue.
    You can get quicker support on CandCNC products on the CandCNC Support forum on Yahoo
    TOMcaudle
    www.CandCNC.com
    Nov 2012
    64
    Having just had a gearing tutorial today from AJ you got me thinking as well
    In one of your earlier posts you mentioned this as the spec of your gearing, maybe I have it wrong (quite possible) but should your 'sprocket' and 'pinion 1' not be the same diameter to get the 3.6:1 ratio 72/18???
    Sprocket: Modul 2 - 20 Teeth - Diameter: 44mm (1.73 Inches)
    Pinion 1: HTD 15mm - 18 Teeth - Diameter: 28,65mm (1.13 Inches)
    Pinion 2: HTD 15mm - 72 Teeth - Diameter: 114,59mm (4,51 Inches)
  1. x axis steppers out of sync
    By normalform in forum DIY CNC Router Table Machines
    Last Post: 02-13-2013, 01:08 PM
  2. Slaved stepper axis out of sync (Lag) Mach3
    By LazyMan in forum DIY CNC Router Table Machines
    Last Post: 12-30-2011, 01:53 AM
  3. Sync. Spindle and A Axis
    By itstom in forum Haas Mills
    Last Post: 07-07-2011, 06:52 PM
  4. X axis out of sync
    By Arif Fayyaz in forum Controller & Computer Solutions
    Last Post: 03-28-2011, 12:26 PM
  5. Haas A axis sync speed
    By HuFlungDung in forum Haas Mills
    Last Post: 10-24-2008, 04:32 AM
