Hello all I was wondering if anyone has used a plunge mill toolpath in mastercam specifically the one in rough surface ? I have mastercam x 6 and i used it defined my tool and i even put out a decent toolpath one problem iscar plunge mill cutter says to move horizonataly at the bottom of the plunge stroke 45 degrees and move .020 then go up to the top of the part and proceed to the next plunge point. My question is where do you input the 45 degree and minimum movement of .020 ?I was hoping this is a common newbie question for using plunge mill cutters with mastercam and any and all help is greatly appreciated
