Hey guys, I got some great help here last time for some countersinking issues that I was having. So figure I will ask another question.
We have a Multicam 5000 series router here, and use enroute to program. My issue is, at random when running a file, it will just slam the bit down into the material at full tilt. Other times it will plunge at the rate I have set it too.
There is no pattern to it, or no certain area of the table that it happens in. Its totally random. But its killing our bits, breaking the tips off our carbides when it slams into a piece of aluminum like that.
I have set the max values to 12 in/min plunge speed in enroute, and it still does it.
Any suggestions, or places to check? Multicam keeps saying its a programming issue, but then why does it only do it at certain times. Everything is programmed at the same plunge rate of 12 inch/min.....
Thanks in advance for any help!
