I am not sure if this is the correct forum and i apologize if it is not.
I need to hook up a switch that will turn on a pump to spray material for a certain amount of time, kind of like a one time shot of lube.
The mechanism goes up and down so as it comes down, let's say 1/2" before it contacts the material, it hits a switch to activate a small 12 volt pump to spray the material then stops. The mechanism goes back up and the whole process is repeated. I hope i have explained this good enough for you to understand i will be using a small 1GPM Flotec pump 12 volt that will have spray nozzels in position.
Thank you
