I believe this machine should have two spring loaded center off switches right near the CRT. One will say spindle enable and something else (cycle start), the other will be for forward or reverse.
You need to hold the Forward/reverse to one side and then turn spindle enable to turn the spindle ON.
Check way oil level because it will not start if the oil is low. There is a Spindle motor overload as well that may be tripped. Someone may have tried starting the spindle with the air off, thus the brake would not release and it may have tripped the overload.
George
