587,829 active members*
2,866 visitors online*
Results 1 to 5 of 5
    Sep 2007
    21
    Hello,
    I've got a question for the controller 16i-TB which is doing its work on a sliding headstock lathes.
    Is it possible to request the downtime at any parameter?
    Means, if the machine was standing more than 15 minutes
    (e.g. no bar change in break) than something should happen!
    Thanks a lot in advance,
    Best regards
    What should happen? Does an alarm start?
    <!--coloro:#48D1CC--><span style="color:#48D1CC"><!--/coloro--><!--sizeo:3--><span style="font-size:12pt;line-height:100%"><!--/sizeo-->Ich bin der Dreher eillig, was ich nicht Drehe das Feill ich<!--sizec--></span><!--/sizec--><!--coloro:#4169E1--><span style="color:#4169E1"><!--/coloro--><!--colorc--></span><!--/colorc-->.<!--colorc--></span><!--/colorc-->
    Spindle and KSS pump on, so that the boss does not realize, that the machine is not generating any turnover :-)
    <!--coloro:#0000FF--><span style="color:#0000FF"><!--/coloro-->Der Vorteil der Klugheit besteht darin, daß man sich dumm stellen kann.<br />Das Gegenteil ist schon schwieriger.<br />Kurt Tucholsky <!--colorc--></span><!--/colorc--><br /><br />GRUß<br /><br />HOLZSCHNELLER CHRISTIAN<br /><br />Mori Seiki <!--coloro:#FF0000--><span style="color:#FF0000"><!--/coloro-->NV5000 α1B/40<!--colorc--></span><!--/colorc--> // <!--coloro:#FF0000--><span style="color:#FF0000"><!--/coloro-->NMV5000<!--colorc--></span><!--/colorc-->// hyperMILL// HSMWorks // Fanuc 31iA5
    Sep 2007
    21
    No, a measurement cycle should be started!
    Noone an idea?
