587,092 active members*
4,173 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > VMC40 Program Stops
Page 1 of 2 12
Results 1 to 20 of 21
    Jun 2007
    92
    VMC40 Program Stops
    Re: VMC40 w/88HS control
    The program so far is:
    N1 G90 G80 G70 G40 G17 G0
    N2 (EM 0.750)
    N3 M6T5
    N4 S2500 M3
    N5 G0 G90 X-.88 Y.5 E1
    N6 H5 Z1. M8
    N7 G1 Z-1. F8.
    N8 G1 Y-6.5 F.8
    N0 G0 Z1.
    (and more...)
    The problem is that the program stops after N6. I'm sure I'm doing something wrong but what is it????
    Jan 2005
    53
    So far, program looks ok. You may want to check to make sure there are no values in last home position or fixture offsets for an axis that is not there.... ie an A axis that has been disconnected, or a value that is not suppose to be there in the offset page.
    What exactly is the machine doing? Does it generate a fault? If you press slide hold, does the machine go into "slide hold"? If so, then the machine is waiting for something, be it a sensor, or an axis move.
    900
    IS there any error codes? Are you running DNC? How old is your software? Email me your full program downloaded directly from your machine not a copy off your computer.
    I'll check things out for your. Also include all offsets. Describe exactly what happens when it "stops". Does it just stop in place and the spindle keep running or does it dump out of the program and return to ENTER NEXT COMMANd?
    Neal
    [email protected]
    Jun 2007
    92
    Okay, it's Monday morning, I fired up and checked for unusual or hidden programs and I've pulled most of the rest of my hair out!
    I did find three subroutines apparently left by the previous owner and one of them referred to T5...thought I had the answer. I deleted all three, re-ran my program and once again it stops (with the spindle running) after it executes N5. If I hit Slide Hold I get the flashing message Slide Hold. There are no error codes. There are five other programs, 774 thru 778, all labeled (Maint) and I figured I shouldn't touch them. I haven't pulled them up so I don't know what they say. I'm programming directly from the control panel and no DNC
    Nov 2007
    17
    Put the H5 on its on line, I think it's trying to put the heigth comp on at the same time it's starting the cut.
    Jun 2007
    92
    Tried that, all it did was drop the tool down to "gauge point" then up one inch then it stops. I've also tried the power down/power up but it still stops.
    I'm completely baffled.
    Jun 2009
    135
    Does line N6 need G43?
    Nov 2007
    17
    N1 O1 PROGRAM NUMBER 1 NOTE PROGRAM NUMBERS ALL START WITH THE LETTER O NOT THE NUMBER 0
    N2 G90 G80 G70 G40 G17 G0
    N3 (EM 0.750)
    N4 M6T5
    N5 S2500 M3
    N6 G0 G90 X-.88 Y.5 E1
    N7 H5 Z1. M8
    N8 G1 Z-1. F8.
    N9 G1 Y-6.5 F.8
    N0 G0 Z1. YOU CAN NOT USE A LINE NUMBER 0
    DID YOU DO A SUM OF THE PROGRAM BY TYPING IN SUM AT THE COMMAND PROMP AND HITTING ENTER?
    IT WILL TELL YOU WHAT LINE NUMBER IS THE PROBLEM
    I RAN THE PROGRAM AS ABOVE WITHOUT THE LAST LINE AND IT RAN FINE.
    Feb 2008
    547
    rdoty,
    It sounds like it's waiting for something, an operation to finish or command. It should time out if there was a electrical or mech. problem.
    Do as Neal asks down load directly, if you can, and send it to him. Tell us more about how you set the job up. (i.e. the preparation)
    AKelly’s program is good, try it.
    If it will not run:
    How exactly are you turning the machine on and getting it homed?
    How are you setting part home?
    How are you touching off your tools?
    In the tool offset page what does offset height read for that tool?
    (In other words the basics first must be right. OK? Unlikely the problem but… you never know)
    If you can down load the program do so and look at it in “notebook” then delete the original and reload from the notebook copy. I once had a program not run and that fixed it. I think there were ‘ghost’ characters in that one.
    Steve
    Jan 2004
    3154
    Sounds like there is something wrong in the E1 offset table.
    Do you by chance have a setting in the A or B column?
    If so delete it.
    www.integratedmechanical.ca
    Jun 2007
    92
    To clarify, in the interest of brevity I typed the important lines of the program in my orig posting but so that it's clear below is exactly as it appears on the screen..
    N0.0010 0101
    N1 (BASE 21033)
    N2 (TRIM LEN)
    N3 G90 G80 G70 G40 G17 G0
    N4 (EM 0.750)
    N5 M6T5
    N6 S2500 M3
    N6.1 G0 G90 X-0.88 Y0.5 E1
    N7.1 Z1. M8 H5
    N8 G1 Z-1. F8
    N9 G1 Y-6.2 F8
    N10 G0 Z-1. F8
    THE TOOL OFFSET IS 0.7500 -10.1262
    FIXTURE 1 IS -3.6450 2.6980 0.5000 (No A OR B values and no other fixtures listed)
    SUM is X=-4.525 Y=-3.552 Z=0.5000 (does that look right???)
    at stop the screen displays:
    H5= -10.1260 D0=0
    F8 S2500 G1 G8 G17 G40 G70 G80 G90 G98
    PROG NO. 101 BLK SKIP OFF
    OPT STOP OFF
    N8 ........
    When I turn the machine on I do a CS. When I turn the machine off I make sure everything is at zero than do a CS then turn the machine off.
    Not sure how I can download the program since I don't have any serial hookup yet.
    Jun 2009
    135
    There is a feed rate of F8 this is 0.0008 IPM which would seem like the machine stopped.
    If the feed rate is F8. disregard this reply.
    Feb 2008
    547
    Quote Originally Posted by JimBoyce View Post
    I agree with Jim. Hope that's it.
    Steve
    Jun 2007
    92
    The machine code is actually F8. so it should be 8ipm.
    Sorry for the confusion.
    Does the SUM look correct, especially the Y being -3.552?
    I keep looking in every corner of the machine parameters but I can't find anything that would cause it to stop. Is there some "look ahead" command that is in some obscure location that I've overlooked?
    Nov 2010
    G43 is missing on line7.1. The machine doesn't know the height offset for T5. I'm surprised it didn't crash.
    Dan
    Jan 2004
    3154
    G43 is not required and the H5 is on the line with the first Z move - this is all good AFAIK
    4826
    Quote Originally Posted by DareBee View Post
    Why is no G43 required? There is an opposite option: G44 would reverse the direction of tool length offset (on a Haas and I assume others), so would it not be a good plan to spell it out completely, leaving no stone unturned, so to speak, when troubleshooting?
    900
    The G43 is a Fanuc style code and the Fadal is written to recognize it to be compatible with Fanuc written programs and not error out BUT the G43 code function is built into the standard Fadal "H" code therefore it is NOT needed is either Format 1 or Format 2.
    Neal
    Jun 2007
    92
    Angry Red faced, he responds
    First, I want to thank everybody for their input.
    Second, I want to tell you that the problem is now solved!
    I won't go into detail or say what the issue was but I will describe the conversation that I had with Douglas at the Fadal Factory Support (great guy by the way). The conversation went something like this:
    Me: Hi Douglas. I've got this problem that has me pulling my hair out.
    Doug: Okay, describe to me what it is doing.
    (I describe and the program continues to stop)
    (I single step through the program and it stops)
    (I read off the program line by line)
    (I read off the X, Y and Z positions)
    Doug: Now you say the machine is not moving? Bob, tell me what the feed rate dial is set at.
    Me: Uhhhh, let's see, it's set at....uhhhh....(expletive).....gosh, Douglas, it's set at....uhhhhh...crap!......uhhhhhhh.....(faintly) zero.
    I hope you guys had a great Thanksgiving and enjoy a very merry Christmas. Me...I'm going to go crawl in a hole!!
    4826
    That can happen
Page 1 of 2 12
  1. spotdrill program stops for no reason?
    By rob jerico in forum Fadal
    Last Post: 10-15-2010, 05:58 PM
  2. Fadal 4020 stops at line 13 or 16 in program
    By ThatguyDave in forum Fadal
    Last Post: 09-09-2009, 08:57 PM
  3. VF-2 stops in the middle of a program!!
    By southernexplore in forum Haas Mills
    Last Post: 08-12-2009, 06:34 PM
  4. Replies: 0
    Last Post: 06-30-2007, 10:13 PM
  5. just got my vmc40 any one know about it??
    By chrisw765 in forum Fadal
    Last Post: 12-04-2005, 03:39 AM
