That is not necessarily true of sophisticated control anyway, where the loop is closed back to the intelligent control, most amplifiers today operate in the torque or current mode of operation where the control outputs a voltage to the amplifier which is directly proportional to the current out to the motor, the encoder feeds back the position to the control, if the control detects that the motor is not in position or is not moving to the degree programmed by the voltage, the motor current will be proportional to the error. If the motor is moved to a position and brought to rest the encoder tells the control it is in position and no further output is neccessary and will be zero, if the motor moves by virtue of external forces then the correction will be made, otherwise there is no need to output.
If you experience an amplifier that appears to be constantly active (sings) and exhibits fine oscillation even when it should be at rest, it is usually due to too high a gain adjustment of the amplifier itself.
Al.
Albert E.
