587,443 active members*
3,269 visitors online*
IndustryArena Forum > CAM Software > SprutCAM > How to limit Z depth on rotary machining?
Results 1 to 4 of 4
    Apr 2012
    9
    So I profiling a 4th axis part using a linear motion from 1" bar stock. My machining operation is Rotary Finishing. X Zero is the right hand end of the bar stock and both Y and Z zero are center of the bar stock. Sprutcam tells the machine to plunge clear to the other side of the bar stock (or Z -0.5") every time it returns to X Zero. I assume the is to surface the face of the part at the end of the bar stock.
    However, I want no more that .75" of stick out on my 1/4" end mill to reduce chatter. So I need to establish a safe Z depth for Sprutcam to use. For the life of me I can not find one. Is there a way to establish a mazimum Z depth for a rotary machining operation in Sprutcam?
    - - - Updated - - -
    forgot to mention I'm using Sprutcam 8 on a Tormach mill (both 770 and 1100)
    Apr 2012
    9
    ended up writting a regex string to parse the code and look for an Z movement less than -0.25 and make it = Z-0.2500 works like a charm, but there really has to be a way to do this in sprut cam.
    Apr 2012
    9
    if you are intersted this is the regex i used
    (Z-0.)[2-9][5-9][0-9][0-9] <-- put in find box
    $1 2500 <-- put in replace box
    May 2024
    1
    Re: How to limit Z depth on rotary machining?
    In your rotary finishing toolpath parameters, locate the section for setting Z depth or clearance depth.
  1. HAAS TR160 Rotary table a-axis limit
    By subaueru in forum Haas Mills
    Last Post: 03-16-2012, 03:22 PM
  2. Replies: 2
    Last Post: 02-04-2012, 05:27 PM
  3. Replies: 1
    Last Post: 01-01-2010, 12:50 PM
  4. STL cutting depth limit?
    By InspirationTool in forum DeskCNC Controller Board
    Last Post: 10-31-2006, 12:11 AM
  5. rotary 4 ax depth of cut q.
    By nervis1 in forum Mastercam
    Last Post: 03-24-2005, 11:34 PM
