587,125 active members*
2,712 visitors online*
Results 1 to 2 of 2
    Aug 2013
    194
    Angry Broke the damn drawbar (zx45)
    Mercury in retrograde for sure......... I may have been over torquing to get things to stop spinning in the R8 collet. Went to loosen the bar and the head snapped right off. Just enough meat I could tap it with a hammer to knock the collet loose but she is down until I fix that thing. Looking at the shaft it is clearly cast. No point in welding it back together other than a cheap fix that will potentially fail.
    Aug 2013
    194
    Re: Broke the damn drawbar (zx45)
    I suppose I should have given an update to this I fixed it some time ago.
    Since I do not have access to a lathe I wound up ordering a replacement from Wholesale Tool co.
    part number 3006-9001
    This one is pretty nice since it has an actual nut and threaded on both ends, so if you break it you can just flip it, also gives you a little more flexibility on the length as a result.
  1. Damn door interlocks!!
    By MarkSerbu in forum Haas Mills
    Last Post: 11-16-2012, 03:50 PM
  2. damn that thing
    By MIYANO vs FANUC in forum Fanuc
    Last Post: 09-27-2011, 03:48 PM
  3. damn this cold weather
    By stk2008 in forum DIY CNC Router Table Machines
    Last Post: 12-16-2010, 03:08 PM
  4. Damn Weather
    By cadmonkey in forum Benchtop Machines
    Last Post: 01-05-2009, 12:00 PM
  5. damn wood routers
    By sdwilson in forum Mastercam
    Last Post: 08-15-2003, 03:15 PM
