587,833 active members*
3,127 visitors online*
Results 1 to 5 of 5
    May 2009
    1346
    Simple AC Wiring Schematic
    Haven't done wiring for some time and I would like to know if the attached schematic is ok before I turn ON the power. It's for the control panel for my new CNC and will supply power to PSU's feeding the stepper motors etc. The DIN terminals shown represents one terminal but there are actually 5 for the Black wire and 5 for the White.
    Nicolas
    Dec 2003
    24220
    Re: Simple AC Wiring Schematic
    Technically you are required to remove power to motorized equipment in the case a an E-stop.
    For cabinet enclosure wiring there is the necessary requirements in NFPA79, there is a copy out there on the WEB, if you cannot find it I can send a copy over.
    Albert E.
    May 2009
    1346
    Thanks for your time Al,
    The E-stop wiring is not shown here because is part of the wiring of the BOB where I wire the E-stop as "Hardware Disable"
    Regarding my cabinet enclosure it definitely will not conform to NFPA79 or anything similar. My enclosure is plywood made since it's for a home made hobby cnc mill.
    So talking just about my wiring schematic when I apply power will it blow the fuse or it is OK?
    Nicolas
    Dec 2003
    24220
    Looks OK , I assume the DIN rail is showing the entry terminations?
    Albert E.
    We have lots of connector boards for servos:
    https://cnc4pc.com/motion-control/sp...or-boards.html
    Feel free to open a ticket on our website and we will help you integrate your servo:
    https://cnc4pc.com/contact
    Arturo Duncan
    https://cnc4pc.com
  1. Full wiring Schematic
    By xillianto in forum X3/SX3/G0619/G0463
    Last Post: 05-11-2023, 12:44 AM
  2. Need a simple schematic for interrupter - LinuxCNC
    By SharpShooterSer in forum Benchtop Machines
    Last Post: 08-10-2016, 12:15 AM
  3. X2 Wiring Schematic
    By QSPSB in forum Benchtop Machines
    Last Post: 03-13-2011, 05:47 PM
  4. Looking for BOSS 5/6 wiring schematic
    By dandonegan in forum Bridgeport / Hardinge Mills
    Last Post: 11-22-2006, 11:06 PM
  5. Simple unipolar schematic, opto isolated
    By Konstantin in forum CNC Machine Related Electronics
    Last Post: 03-31-2004, 12:02 PM
