587,756 active members*
5,008 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Motor siezes up on Benchtop mill
Results 1 to 4 of 4
    Oct 2009
    2
    Hello, I have a benchtop mill. Not sure what brand it is but it's made in India. The Y motor went back to far and pushed the bearing out of it's housing in back of the machine and siezed the motor up. I bought a new motor and installed it and that motor also siezes up. I think the problem might be in the board of the controller, it is a DSP Servo 511, but I'm not sure what to look for on the board, or where to buy a new board. We are running Mach 3 with it.
    Apr 2005
    862
    Are you sure it is the motor? Can you run the new motor in free air? I would be suspicious that the bearing that was pushed out might be damaged, or the screw or nut may be out of alignment after the crash, causing binding.
    Oct 2009
    2
    Yes, the new motor siezes up in mid air.
    Sep 2009
    11
    Did you see if a controller from one of the other axis seizes your new motor?
  1. Looking to by CNC Benchtop mill
    By vtracer in forum Benchtop Machines
    Last Post: 05-28-2008, 11:33 PM
  2. BenchTop Mill to Buy
    By leeschaumberg in forum Benchtop Machines
    Last Post: 04-10-2007, 10:57 PM
  3. Has anyone seen this benchtop mill before ?
    By jeff2005 in forum Benchtop Machines
    Last Post: 02-11-2007, 04:46 PM
  4. Not Exactly a Benchtop Mill
    By dcprecision in forum Benchtop Machines
    Last Post: 09-28-2006, 03:58 PM
