587,215 active members*
3,965 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Damn the power and coolant switches being side by side!
Results 1 to 18 of 18
    Mar 2013
    131
    And looking identical!
    So I reset a program right in the middle of it. At least it was a small part.
    This is my solution for now:
    This is coming:
    I'll eventually get this thing fully enclosed and will move all this away anyway but for now I will do the toggle switch and cover.
    Oct 2010
    670
    Re: Damn the power and coolant switches being side by side!
    You could also paint them with model paint. Red/Green on the toggle for power and blue for the coolant. I like the flip up cover.
    The Body Armor Dude - Andrew
    Jun 2014
    1780
    I have the same gripe, I have turned off the computer many times thinking it was the coolant switch. I thought about using the key switch position for it, as I never use the key switch anyway.
    mike sr
    Mar 2013
    131
    Quote Originally Posted by smokediver576 View Post
    I thought about it but I usually am messing with it as I am looking at the part so I am just touching it. I stretched to move something and slightly repositioned myself and turned the computer off instead since they feel the same.
    Mar 2013
    344
    Add me to the list of people who have done that and trashed a part.
    Jul 2007
    438
    The coolant and interior light buttons are right next together on my turning center. More than once I've turned the coolant on with the door open while doing a setup. The coolant pressure and volume is just a bit more than a Tormach.
    Jul 2011
    297
    oddly enough, I think this is the one "operator induced error" I have not committed... I am feeling pretty good now knowing there is at least one thing I have not screwed up with my mill...
    so, thanks for that
    NOTE:As one wise professional something once stated, I am ignorant & childish, with a mindset comparable to 9/11 troofers and wackjob conspiracy theorists.
    Nov 2007
    2151
    Quote Originally Posted by SomeWhatLost View Post
    so, thanks for that
    +1
    I Mostly use only the on and off switch and most my errors are pebkac errors. "Problem exists between keyboard and chair" This is also a common error i run into when drawing and creating cam tool paths.
    Nov 2012
    1270
    Sadly, many control panels look just like that. Geometrically arranged rows of buttons/switches with no consideration for ergonomics.
    Imagine a car dashboard where you could accidentally switch off the engine instead of turning the windshield washer on.
    Aug 2015
    41
    I hit mine once, I had a really sad look on my face. I run heavy flood and the PLC cabinet doesn't have the greatest seal so I have put a piece of plastic over it. That has forced me to use the controls in path pilot. If you can force yourself to operate everything from there then you shouldn't make that mistake, it is working for me thus far.
    Nov 2007
    2151
    LOL,
    I realized that switch has no function on my mill. I use a ups on my machine controller and it cant lose power even if the power goes out
    Mar 2013
    131
    Quote Originally Posted by mountaindew View Post
    LOL,
    I may just plug the computer into the wall and on a power strip.
    I'll just use a new power cable and keep the one plugged into the machine since the Tormach is in a corner and reaching the plug would be too much headache.
    Nov 2007
    2151
    Quote Originally Posted by eltejano View Post
    The ups plugs into wall and controller direct to ups and also a switched strip on front side of tool box. Controller is mounted to back of tool box
    .Attachment 354336
    I mount these to side of all my rolling tool boxes
    Attachment 354338
    Mar 2013
    131
    .Attachment 354336
    Attachment 354338
    This is a very clever setup. I had something similar in mind but I may go with a UPS, as well. Thanks for sharing.
    Nov 2007
    2151
    I must warn you those switches are handy but can be bumped with vac hose or leg and off they go. I use them most to power all the little gadgets,battery chargers, tablets, monitors and led task lights that end up on my work stations. Most cord power tools are plugged in on overhead cords.
    I use mostly task lights these days. 1000 watts of overhead 4 ft lights generate to much heat and co$st money. Need to rewire them to be switched in banks so I can use sets over mill , bench, and jeep. Another project
    Nov 2007
    2151
    Thanks! Always fun to share pics of where you practice your craft whatever it is. You should see my Swiss Army router, table saw And having a tormach mill makes it even better. I make tools, fixtures, attachments, guides, rulers, fences, sliding guides, offset stops.... the shop is half full of things that attach to it
    Feb 2007
    1538
    Glad I am in good company - I have done that at least twice, and lost a lot of time.
    One good thing has come of it....I think it has finally taught me to concentrate more!
    Keen
    Jul 2016
    140
    Add me to the list. I've done it once. Now I keep the coolant switch on Auto and use the coolant button in PP instead.
    Tormach PCNC 1100 Series 3 w/ Rapid Turn, Fusion 360
  1. Compare Mazak programs side by side with diferences highlighted.
    By Raybeamerson in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-12-2017, 05:24 PM
  2. Adjusting CRT Monitor side to side
    By tsrnewlin in forum Haas Mills
    Last Post: 09-14-2010, 01:11 AM
  3. Replies: 13
    Last Post: 07-13-2010, 05:23 PM
  4. Z-axis - mounting rails on spindle side, rather than tower side
    By guru_florida in forum Linear and Rotary Motion
    Last Post: 02-01-2008, 01:54 AM
  5. mounting linear rails side by side
    By 50062040 in forum Linear and Rotary Motion
    Last Post: 10-24-2005, 01:49 PM
