587,850 active members*
3,410 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > FANUC 6M MODEL B CHANGE "[ ]" CHARACTER TO "( )"
Results 1 to 5 of 5
    Jul 2007
    21
    hello everybody in the cnczone
    please help me to change the character "[ ]" to "( )" in my fanuc 6m model b
    Jul 2007
    21
    maybe some parameter is
    May 2013
    128
    param 3 Bit # 3
    Jul 2007
    21
    i tried but it doesn't work
    what is the explanation of parameters 00,01,02,03,04,05
    May 2013
    128
    PARAM_INFO BIT_NO DESCRIPTN KEY
    PARAM 000 1 T/M CIRC. INTER BY RAD.
    PARAM 000 2 T/M ADD 16 OFFSETS MEMORY
    PARAM 000 4 T/M CSS B (ANOLOG OUTPUT)
    PARAM 000 5 T/M G20/G21 SWITCHING (INCH/METRIC)
    PARAM 000 6 T/M REF. POINT RET'N (2ND) 6M 0 RETURN B
    PARAM 000 7 T/M REF. POINT RET'N (1ST) 6M 0 RETURN A (MANUAL,G28
    PARAM 001 0 T/M G90,92/94 CYCLES 6M ADDITIONAL AXIS @SIM CONTROL
    PARAM 001 1 T/M AUTO TOOL COMP. 6M ADDITIONAL AXIS CONTROL
    PARAM 001 2 T/M CHAM. AND CORNER RADIUS.6M SIM. 3 AXIS CONTROL
    PARAM 001 3 T/M TOOL NOSE COMP. (RAD). 6M CUTTER COMP C
    PARAM 001 5 T/M MULTI CYCLES. 6M S2/4-DIGIT BCD
    PARAM 001 6 T/M M.P.GENERATOR
    PARAM 002 0 T/M AUTO ACCEL/DECEL. FOR FEED
    PARAM 002 1 T/M STORE STROKE LIMITS 2 AND 3
    PARAM 002 2 T/M RADIUS PROGRAMMING 6M F1 DIGIT FEED
    PARAM 002 3 T/M STORE STROKE LIMIT 1
    PARAM 002 5 T/M ** TAPE INTERFACE
    PARAM 002 6 T/M INCREMENTAL OFFSETS
    PARAM 003 1 T/M G10 OPTION 6M OFFSET DATA FROM TAPE
    PARAM 003 3 T/M ** ISO INPUT
    PARAM 003 4 T/M CLOCK DISPLAY 6M RUN HOUR DISPLAY
    PARAM 003 5 T/M RAPID TRAVERSE OVERRIDE
    PARAM 003 7 T/M PC MODEL B.
    for 6M
    PARAM 000 0 6M CIRCULAR INTERPOLATION STD G02 G03
    PARAM 000 3 6M SPINDLE SPEED 12 BIT OUTPUT CSS A
    PARAM 001 4 6M CUTTER COMPENSATION B
    PARAM 001 7 6M TWO DIGIT DESIGNATORS T2/T4 TOOL FUNCTIONS
    PARAM 002 7 6M EXTERNAL DECELERATION
    PARAM 003 2 6M HELICAL INTERPOLATION
    PARAM 002 4 6M THREADING AND SYNCROUS FEED
    PARAM 003 0 6M PART PROGRAM CHECKING
    PARAM 003 6 6M STORED PITCH ERROR COMPENSATION
    PARAM 004 0 M TOOL LENGTH COMP. (G43,G44,G49)
    PARAM 004 1 M TOOL OFFSET (G45,G48)
    PARAM 004 2 M CANNED CYCLES B (G73,G74,G80-G89)
    PARAM 004 3 M CANNED CYCLES A (G80,G81,G83,G84,G85,G86,G89)
    PARAM 004 4 M CIRCULAR CUTTING
    PARAM 004 6 M SND AUXILARY FUNCTIONS B-CODE 3 DIDGITS
    PARAM 004 7 M REMOTE TYPE POSITION DISPLAY
    PARAM 005 0 M EXTERNAL WORK NO. SELECT
    PARAM 005 1 M
    PARAM 005 2 M
    PARAM 005 3 M TURRET INDEXING FUNCTIONS
    PARAM 005 4 M FT CENTRE H ATC SPECIAL ATTACHMENT
    PARAM 005 5 M FT CENTRE D/E ATS SPECIAL ATTACHMENT
    PARAM 005 6 M ROBOT INTERFACE
    PARAM 005 7 M NIBBLING CYCLE (WOODPECKER)
  1. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  2. Replies: 2
    Last Post: 11-16-2012, 03:17 AM
  3. Definition of "minimum shaping character"?
    By spincaster in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-07-2012, 11:27 AM
