587,459 active members*
3,844 visitors online*
IndustryArena Forum > MetalWorking Machines > Novakon > Drilled some .012" holes today...
Results 1 to 7 of 7
    Mar 2011
    480
    10 diameters deep. It worked !. I'm sure it's probably not a big deal in aluminum, but it's the first time I've drilled anything that small. I can barely see the drill bit. :-).
    Jun 2008
    1082
    Re: Drilled some .012" holes today...
    Wow, that's quite a feat! ...I think.
    You wouldn't have a photo or something, would you?
    What cut parameters did you use?
    Feb 2006
    7063
    Musta been lots of tiny, little pecks.... Smallest I've ever even tried was about 0.030" diameter.
    Regards,
    Ray L.
    Mar 2011
    480
    Quote Originally Posted by Hirudin View Post
    HSMadvisor recommended 3.3"/min @6000rpm, peck .01". I pecked .006" because I'm chicken, but it worked, no broken bits, so I'm happy. Hopefully you can see the holes in the pic. They are in a spiral pattern.
    Attachment 266990
    Feb 2009
    6028
    That's pretty good. Run out is critical on small drills. I was watching a guy at work drilling .003 holes, can't even see the drills, and the flood coolant would break them! Whole different art below .015.
    Jun 2008
    1082
    Quote Originally Posted by AUSTINMACHINING View Post
    ... Hopefully you can see the holes in the pic. They are in a spiral pattern.
    Attachment 266990
    Yeah, THOSE are tiny! Thanks for the pic!
    Mar 2011
    480
    Quote Originally Posted by underthetire View Post
    I would like to see a video of the tool making these tiny drill bits !
  1. Pre drilled holes machining
    By mousongie in forum UG NX
    Last Post: 12-17-2013, 09:58 PM
  2. Replies: 10
    Last Post: 04-19-2012, 05:03 PM
  3. Rearrange order of holes drilled ?
    By TronCarter in forum Uncategorised CAM Discussion
    Last Post: 01-06-2009, 04:34 AM
  4. projecting drilled holes
    By dpark1 in forum Mastercam
    Last Post: 08-25-2007, 04:17 AM
  5. Drilled Holes
    By jonbanquer in forum NCPlot G-Code editor / backplotter
    Last Post: 05-25-2005, 05:17 AM
