I am fairly new to the thread rolling process having only been doing it for about 8 months now. I have a pretty good understanding of the machines I'm running and have been fairly successful in making parts. For the most part, I run out bolt blanks. I'll cut them to size, grind to the required roll dimension, and then roll them. I'm using a Cincinnati #2OM to grind and a Reed B-112 thread roller to make my threads. My grind is straight and all is well. I'm having a hard time rolling the threads due to what I think are issues with the material. I have never worked with a 410 stainless before and it seems to splinter more than anything while it's rolling. Dies are matched, work rest blade is at the proper height, I've slowed my feed rate speed down quite a bit but I can't seem to fix the issue. There is a call out for a 32 finish and I can't achieve this with the material splintering every time it rolls! Any suggestions would be greatly appreciated!!! Thanks!
