587,515 active members*
2,976 visitors online*
Thread: VFD Inverter
Results 1 to 2 of 2
    Mar 2008
    38
    VFD Inverter
    My shop has only single phase power, all our big 3 phase equipment we run off a 20 HP rotary phase converter. I would like to build the cnc router controller to accept only single phase so i dont have to worry about the wild leg which i know is there some days....and bad. My cnc has 2 variable speed 5hp spindles, a non variable 3hp spindle and a 4hp 3 phase motor that drives the drill bank.
    I am getting a VFD inverter for the variable speed spindles, but could i use the vfd for the non variable and use it just as a phase converter? Only one motor will be running at a time and i would set up a series of contactors controlled by the computer to switch them. Does this sound feasable or am i missing something?
    Dec 2003
    24220
    I would only consider it if all the motors were the same type and configuration/rating.
    You normally set the parameters up for one particular configuration of motor, so mix and matching them may cause you to run into a few different problems.
    Even running two motors simultaneously off of one VFD, the motors should be the same and the rpm and load should not differ by more than 10% between each.
    Going with a make like WEG, you can get free engineering advice on their product usage.
    Al.
    Albert E.
  1. Inverter Units MIV
    By Antonio Arguijo in forum Okuma
    Last Post: 02-02-2011, 02:50 PM
  2. Inverter Problems
    By mikemill in forum Uncategorised MetalWorking Machines
    Last Post: 09-03-2010, 01:30 PM
  3. Inverter
    By vivagolf in forum DIY CNC Router Table Machines
    Last Post: 11-04-2008, 12:55 AM
  4. Power inverter
    By beartrax in forum Fadal
    Last Post: 09-30-2008, 04:10 PM
  5. Inverter setup
    By multex1 in forum Phase Converters
    Last Post: 08-25-2007, 03:56 AM
