Originally Posted by
cr4ck3r
Well With no true explanation it is fixed. Indexing the table 180 degrees in MDI mode the rotating table clamped and it worked. The problem couldn't be recreated either. Just thought I'd comment about this in case anyone else ever comes across the problem.
Our 500s with OSP 200M controls do it regularly. If you read the pocket manual, if you have it on the control, it will tell you in that situation to index the table to any position as you found by trial and error. I've had to train my more advanced operators on how to do go into the APC screen from manual mode and step through. If they can't restart then they are to go back into that screen, return cycle and then to MDI and enter in the g codes to index. After that to clear the chips from the loading area. What the normal cause is with ours is either chips building up as said by supercut or the dog that trips the limit switch at the loading station is out of whack, which in our case is from operators letting the pallet lock stop a rotating pallet. When it does it again don't reset just hit the APC button and look for errors at the bottom of the screen LS does not exist with some address characters means a sticky limit switch or something similar preventing the control from reading a ready state. One other thing that will happen is if someone uses the tool probe sometimes chips will prevent it from closing completely and that limit switch will prevent it from indexing since it thinks the probe is still up. It still gives an APC Clamping alarm but the error is Tool Probe LS up or something similar. Don't know if you are using a probe to check for tool breakage but if so it could be chips falling under the cover on the side away from the spindle preventing it from completely dropping down. Hope this helps.
Suppose you were an idiot and suppose you were a member of Congress. But I repeat myself.
Mark Twain
