Hello all,
I have just purchased a 1992 Dynapath w/a delta 10 controller to do some side work in my garage.
When drilling a series of holes ,the machine runs fine as long as I program the holes from right to left
(always traveling in the negative direction.) If I program a feature location that makes the machine travel in a positive direction
the machine will travel to the location and just sit there w/ no alarms.
I also have the same problem if at the end of a program when the machine returns to the home position.
If it travels in a negative direction the spindle turns off and the light on the cycle start button turns off.
but if the machine travels in a positive direction ,it moves to the home positions and just sits there
w/ the spindle still turning and the cycle start button still remains lit.
Any suggestion how I can fix this problem myself would be greatly appreciated.
Thanks in advance.
Brian
