587,243 active members*
3,206 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > 099 P/S ALARM FANUC 0M during ATC
Results 1 to 3 of 3
    Jan 2009
    117
    Eumach machine with FANUC 0MC and umbrella type toolchanger.
    The ATC uses a macro program O9001 to run the ATC sequence as well as the PMC.
    099 P/S ALARM appears as soon as the carousel moves toward the spindle during the M06 sequence.
    When the program is in single block, the problem appears when G30 Z0. command is read by the control in the macro.
    Part of the program where the problem occurs:
    N60 M6
    N65 G65 H81 P80 Q#1010 R1
    N70 G04 P100
    N75 G65 H80 P65
    N80 G30 Z0.
    099 P/S ALARM: MOVE COMMAND IN MDI AFTER PROGRAM RESTART
    I deactivated the Program Restart option; ensured that G103.0 is OFF in the PMC and there is no "software switch" in the software operator's panel.
    The problem appears in AUTO and MDI modes.
    Please help or advise.
    Regards
    hrh
    Jun 2013
    62
    Quote Originally Posted by hrh View Post
    N60 M6
    N70 G04 P100
    N75 G65 H80 P65
    N80 G30 Z0.
    Regards
    hrh
    Hi
    Did you find any solution for the above probelm.
    Please let me know as I am also facing simillar problem.
    In my case PS090 pops up as soon as M6 is about to finish.
    In my case there is no O9000-O9999 program in machine, same was checked by taking program backup with NE9 off.
    There is no macro cassette in the motherboard.
    M6 is controlled by ladder only.
    Please let me know if you found any solution for the same.
    Rgds
    Harmeet singh
    Dec 2020
    7
    Re: 099 P/S ALARM FANUC 0M during ATC
    I have same problem with my Bridgeport A type CNC Milling Machine with Fanuc OM control. I have no ATC Macro. Please help
  1. Replies: 2
    Last Post: 11-24-2018, 09:15 PM
  2. Replies: 2
    Last Post: 09-10-2018, 09:21 PM
  3. Fanuc 6T-B alarm 402:servo Alarm
    By leiryll in forum Fanuc
    Last Post: 12-03-2013, 08:52 AM
  4. Replies: 0
    Last Post: 08-12-2013, 09:12 AM
  5. Replies: 6
    Last Post: 03-13-2013, 03:32 PM
