Hello,
I have been scouring the internet trying to figure out a way to get my Huanyang HY01D511B 110v VFD spindle to activate the spindle to begin to run with a simple relay.
Machine i am using is a Nextwave Automation Shark HD 510, I sue the pendant to move, load files and start / Stop jobs. NO PC is hooked to it to run it at all. The machine has a controller with a switched 110v output on the back. This normally would be hooked to a 120 palm router and when the g-code would give the command to start, this port become active and turns on the router. I have a simple 110v AC / 24v DC Relay ( https://www.amazon.com/gp/product/B0...0?ie=UTF8&th=1 )
I currently use the machine and just start / stop it with the normal buttons and adjust the speeds. I just want the thing to start running when the relay goes live and shut off then it turns off.
Attached is a picture of the VFD boards and the Relay I also am using.
