587,302 active members*
3,157 visitors online*
Results 1 to 3 of 3
    Sep 2010
    145
    Noise from a hpg, normal?
    Hello: I have a handwheel on my mill, pulse wheel I guess. It makes noise at times, like a frying/squeeling sound. If you move the wheel a bit it changes or goes away. Is this normal? Its a AB unit if that helps.
    Jan 2006
    738
    Where is the noise coming from? The hand wheel? Drive motors? Power board? You may have a very small following error causing a low drive level to the motor. With PWM drive, you may be hearing the pulses (high frequency) trying to correct the error. Moving the wheel, may be correcting the error causing the drive to stop trying to move to correct it.
    Steve
    Dec 2003
    24223
    Normally there is very low current through a H.W. so there should be no electrical noise from the unit itself?
    As Steve mentioned, it sounds more like the servo making the noise?
    Al.
    Albert E.
  1. Need to know if this is normal (DX-32)
    By EFI-Unlimited in forum Bridgeport / Hardinge Mills
    Last Post: 10-06-2010, 09:11 PM
  2. is this normal?
    By 15mgtar in forum Stepper Motors / Drives
    Last Post: 04-01-2010, 12:01 AM
  3. Gremlin or Normal?
    By Mr.Chips in forum Gecko Drives
    Last Post: 01-20-2010, 02:12 AM
  4. Lots of crunching noise from Z axis ballnut. Normal?
    By alexccmeister in forum Benchtop Machines
    Last Post: 08-27-2008, 02:05 AM
  5. This is NOT a normal noise
    By Dancy in forum Fanuc
    Last Post: 05-24-2008, 10:26 PM
