587,518 active members*
3,156 visitors online*
Results 1 to 9 of 9
    Mar 2014
    15
    KL5056d+c10 board +mach3
    Hi guys i am having issues getting the motors to do anything so far.
    I followed the wiring diagram from Keling. But it has wires that intersect eachother and others that jump over. Are all wires that cross eachother ment to be connected?
    Normally they would have a round point to show that they are meant to be connected and then jumps to show that they dont connect.
    Honestly this wiring diagram sucks majorly. Any help would be appreciated.
    http://www.automationtechnologiesinc...oad.php?id=313
    Because if where the wires cross are meant to be connected they will be connecting Positive to Negative from the power supply. I want to be sure because this seems odd to me. Thanks
    Also here is a picture of what i have so far. A little messy because im trying to test motors before i hook any of it up to machine.
ID:	234196Click image for larger version.
    Nov 2013
    88
    Re: KL5056d+c10 board +mach3
    That is a really bad drawing, I can see why you cant make any sense of it.
    They only jumped over the wires that are the same colors, so any wire that looks connected and is the same color is connected together.
    So the black wire at the bottom coming from power supply V- is connected to all drivers, best to run a separate wire to each driver, the drawing shows taps on one wire which is not a good way for power wires, its just easier to draw. Same for the red from V+ but I would recommend separate wires for each driver.
    On the input of the driver the two black wires on each driver are connected together going to dir+ and pul+.
    Mar 2014
    15
    I rewired everything. Everything looks right. If I hold a motor to my ear I can hear some sort of electronic noise. Idk with is wrong.
    Sent from my SCH-I545 using Tapatalk
    Nov 2013
    88
    What about the master enable , that supplies 5 volts to something on the board, cant see that part in the pics.
    Is there +5 volts dc on the dir+ and pul+ to 5 volt gound ?
    Mar 2014
    15
    No it just shows 5 v going to c10 board on schematic. Not to drivers
    Nov 2013
    88
    Right the master enable when the switch is on supplies 5 volts to that pin.
    On the drivers, the way there wired, the dir+ and pul+ should also measure 5+ volts from the 5 volt supply ground.
    Its looks like its setup low pulse, also I believe theres a setting in IO for that in mach3 if thats what your using to control the breakout board.
    Mar 2014
    15
    The link in my first post shows the original schematic that I'm following
    Mar 2014
    15
    No where on there does it show 5v going to controllers. Honestly I just want to get these hooked up the right way and get these motors turning. Is there a different schematic out there that will work?
    Mar 2014
    15
    Just to let others who may have same issue. I didn't have a jumper set correctly. I had com set to ground on the jumper. It needed to be set to 5v. Thanks to those who helped.
  1. Mach3, PWM to DC Conversion Board, CM-112
    By Robiz in forum News Announcements
    Last Post: 10-25-2013, 06:18 AM
  2. Mach3, USB Key Board, CM-111
    Last Post: 10-08-2013, 06:55 AM
  3. KL5056D with C10 and KL600 48V (Steppers Have No Torque!)
    By Voodoo Vintage in forum Automation Technology Products
    Last Post: 12-17-2012, 07:07 PM
  4. breakout board for mach3
    By albaboun in forum Machines running Mach Software
    Last Post: 04-23-2012, 01:43 PM
  5. C35 & KL5056D?
    By Fastest1 in forum Automation Technology Products
    Last Post: 08-06-2011, 03:12 PM
