I have edge came 11.5 and I a making my first part with it. I have two questions.
1.When I made a roughing pass I could not hide the tool path so I could select the model for a finishing pass. There was is much toolpath in the way that I couldnt even see the model. I tried for three hours to hide it. How do you hide it?
2. When I import a solid model with holes that need to be drilled in the center once I select machining mode I cannot select faces one at a time anymore. It will select the whole model for every process so I cant leave out the holes and just machine the faces. It wants to machine the whole part every time. How can I tell it what features I want it to machine so I can do the holes in a different process.
