587,421 active members*
3,377 visitors online*
Results 1 to 4 of 4
    Apr 2012
    45
    Question LinuxCNC axis calibration
    Guys,
    I have made my own mini CNC
    For testing I want to print this one :
    In PC has a display :
    Why is the x axis still out of the limit ? is it because of my setting ?
    Code:
    # Generated by stepconf at Wed Jun 27 18:18:25 2012
    # If you make changes to this file, they will be
    # overwritten when you run stepconf again
    [EMC]
    MACHINE = riko-mill
    DEBUG = 0
    [DISPLAY]
    DISPLAY = axis
    EDITOR = gedit
    POSITION_OFFSET = RELATIVE
    POSITION_FEEDBACK = ACTUAL
    MAX_FEED_OVERRIDE = 1.2
    INTRO_TIME = 5
    PROGRAM_PREFIX = /root/linuxcnc/nc_files
    INCREMENTS = .1in .05in .01in .005in .001in .0005in .0001in
    [FILTER]
    PROGRAM_EXTENSION = .png,.gif,.jpg Greyscale Depth Image
    PROGRAM_EXTENSION = .py Python Script
    png = image-to-gcode
    gif = image-to-gcode
    jpg = image-to-gcode
    py = python
    [TASK]
    TASK = milltask
    CYCLE_TIME = 0.010
    [RS274NGC]
    PARAMETER_FILE = linuxcnc.var
    [EMCMOT]
    EMCMOT = motmod
    COMM_TIMEOUT = 1.0
    COMM_WAIT = 0.010
    BASE_PERIOD = 100000
    SERVO_PERIOD = 1000000
    [HAL]
    HALFILE = riko-mill.hal
    HALFILE = custom.hal
    POSTGUI_HALFILE = custom_postgui.hal
    [TRAJ]
    AXES = 3
    COORDINATES = X Y Z
    LINEAR_UNITS = inch
    ANGULAR_UNITS = degree
    CYCLE_TIME = 0.010
    DEFAULT_VELOCITY = 0.10
    MAX_LINEAR_VELOCITY = 1.00
    [EMCIO]
    EMCIO = io
    CYCLE_TIME = 0.100
    TOOL_TABLE = tool.tbl
    [AXIS_0]
    TYPE = LINEAR
    HOME = -0.1
    MAX_VELOCITY = 1.0
    MAX_ACCELERATION = 30.0
    STEPGEN_MAXACCEL = 37.5
    SCALE = -8000.0
    FERROR = 0.05
    MIN_FERROR = 0.01
    MIN_LIMIT = -0.11
    MAX_LIMIT = 5.5
    HOME_OFFSET = -0.1
    [AXIS_1]
    TYPE = LINEAR
    HOME = 0.0
    MAX_VELOCITY = 1.0
    SCALE = -8000.0
    FERROR = 0.05
    MIN_FERROR = 0.01
    MIN_LIMIT = -0.4
    MAX_LIMIT = 5.0
    HOME_OFFSET = 0.0
    [AXIS_2]
    TYPE = LINEAR
    HOME = -1.1
    MAX_VELOCITY = 1.0
    SCALE = -8000.0
    FERROR = 0.05
    MIN_FERROR = 0.01
    MIN_LIMIT = -2
    MAX_LIMIT = 1.0
    HOME_OFFSET = 2.0
    G-code :
    Code:
    G20
    G0 Z0.0120
    G17 G40
    G80 G90 G94
    S1000 M3
    G04 P3
    G64 P0.0010
    F12.0000
    G18
    F12.0000
    G0 X-0.0534 Y1.6320
    G2 X0.000000 Z0.000000 R0.125000
    F12.0000
    G1 X0.9540 Z-0.0000
    F12.0000
    G0 Z0.0120
     X-0.0534 Y1.5840
    F12.0000
    G1 X0.9540 Z-0.0000
    F12.0000
    G0 Z0.0120
     X-0.0534 Y1.5360
    F12.0000
    G1 X0.9540 Z-0.0000
    F12.0000
    G0 Z0.0120
     X-0.0534 Y1.4880
    F12.0000
    G1 X0.9540 Z-0.0000
    F12.0000
    G0 Z0.0120
     X-0.0534 Y1.4400
    F12.0000
    G1 X0.9540 Z-0.0000
    F12.0000
    G0 Z0.0120
     X-0.0534 Y1.3920
    F12.0000
    G1 X0.9540 Z-0.0000
    F12.0000
    G0 Z0.0120
     X-0.0534 Y1.3440
    F12.0000
    G1 X0.9540 Z-0.0000
    F12.0000
    G0 Z0.0120
     X-0.0534 Y1.2960
    F12.0000
    G1 X0.9540 Z-0.0000
    F12.0000
    G0 Z0.0120
     X-0.0534 Y1.2480
    G2 X0.000000 Z-0.000000 R0.125000
    F12.0000
    G1 X0.9540
    F12.0000
    G0 Z0.0120
     X-0.0534 Y1.2000
    F12.0000
    G1 X0.9540
    F12.0000
    G0 Z0.0120
     X-0.0534 Y1.1520
    F12.0000
    G1 X0.9540
    F12.0000
    G0 Z0.0120
     X-0.0534 Y1.1040
    F12.0000
    G1 X0.9540
    F12.0000
    G0 Z0.0120
     X-0.0534 Y1.0560
    F12.0000
    G1 X0.9540
    F12.0000
    G0 Z0.0120
     X-0.0534 Y1.0080
    F12.0000
    G1 X0.9540
    F12.0000
    G0 Z0.0120
     X-0.0534 Y0.9600
    F12.0000
    G1 X0.9540
    F12.0000
    G0 Z0.0120
     X-0.0534 Y0.9120
    F12.0000
    G1 X0.9540
    F12.0000
    G0 Z0.0120
     X-0.0534 Y0.8640
    F12.0000
    G1 X0.9540
    F12.0000
    G0 Z0.0120
     X-0.0534 Y0.8160
    F12.0000
    G1 X0.9540
    F12.0000
    G0 Z0.0120
     X-0.0534 Y0.7680
    F12.0000
    G1 X0.9540 Z0.0000
    F12.0000
    G0 Z0.0120
     X-0.0534 Y0.7200
    F12.0000
    G1 X0.9540 Z0.0000
    F12.0000
    G0 Z0.0120
     X-0.0534 Y0.6720
    F12.0000
    G1 X0.9540 Z0.0000
    F12.0000
    G0 Z0.0120
     X-0.0534 Y0.6240
    F12.0000
    G1 X0.9540 Z0.0000
    F12.0000
    G0 Z0.0120
     X-0.0534 Y0.5760
    F12.0000
    G1 X0.9540 Z0.0000
    F12.0000
    G0 Z0.0120
     X-0.0534 Y0.5280
    F12.0000
    G1 X0.9540 Z0.0000
    F12.0000
    G0 Z0.0120
     X-0.0534 Y0.4800
    F12.0000
    G1 X0.9540 Z0.0000
    F12.0000
    G0 Z0.0120
     X-0.0534 Y0.4320
    F12.0000
    G1 X0.9540
    F12.0000
    G0 Z0.0120
     X-0.0534 Y0.3840
    F12.0000
    G1 X0.9540
    F12.0000
    G0 Z0.0120
     X-0.0534 Y0.3360
    F12.0000
    G1 X0.9540
    F12.0000
    G0 Z0.0120
     X-0.0534 Y0.2880
    F12.0000
    G1 X0.9540
    F12.0000
    G0 Z0.0120
     X-0.0534 Y0.2400
    F12.0000
    G1 X0.9540
    F12.0000
    G0 Z0.0120
     X-0.0534 Y0.1920
    F12.0000
    G1 X0.9540
    F12.0000
    G0 Z0.0120
     X-0.0534 Y0.1440
    F12.0000
    G1 X0.9540
    F12.0000
    G0 Z0.0120
     X-0.0534 Y0.0960
    F12.0000
    G1 X0.9540
    F12.0000
    G0 Z0.0120
     X-0.0534 Y0.0480
    F12.0000
    G1 X0.9540
    F12.0000
    G0 Z0.0120
     X-0.0534 Y0.0060
    F12.0000
    G1 X0.9540
    G0 Z0.0120
    F12.0000
    F12.0000
     X-0.1243 Y1.6320
    G2 X0.000000 Z-0.100000 R0.125000
    F12.0000
    G1 X0.1500
    G2 X0.1620 Y1.6320 Z-0.0203 I-0.6816 K0.1433
    G3 X0.1860 Y1.6320 Z-0.0090 I0.0240 K-0.0200
    G3 X0.2100 Y1.6320 Z-0.0160 I-0.0020 K-0.0516
    G1 X0.2160 Z-0.0140
     X0.2280
    G3 X0.2520 Y1.6320 Z-0.0273 I-0.0065 K-0.0400
    G1 X0.2580 Z-0.0386
    G2 X0.2700 Y1.6320 Z-0.1000 I0.2930 K0.0254
    G1 X0.2940
     X0.3000 Z-0.0425
     X0.3060 Z-0.0224
    G3 X0.3300 Y1.6320 Z-0.0108 I0.0240 K-0.0191
    G3 X0.3480 Y1.6320 Z-0.0153 I-0.0012 K-0.0430
    G1 X0.3660 Z-0.0155
     X0.3780 Z-0.0179
    G3 X0.3960 Y1.6320 Z-0.0333 I-0.0189 K-0.0404
    G1 X0.4020 Z-0.0861
     X0.4080 Z-0.1000
     X0.9540
    F12.0000
    G0 Z0.0120
     X-0.1243 Y1.5840
    F12.0000
    G1 X0.0420
     X0.0480 Z-0.0868
     X0.0540 Z-0.0374
    G3 X0.0720 Y1.5840 Z-0.0239 I0.0248 K-0.0144
    G3 X0.1020 Y1.5840 Z-0.0177 I0.0315 K-0.0764
    G3 X0.1200 Y1.5840 Z-0.0234 I-0.0003 K-0.0321
    G3 X0.1440 Y1.5840 Z-0.0030 I0.0333 K-0.0149
    G1 X0.1620
     X0.1740 Z-0.0070
    G3 X0.2040 Y1.5840 Z0.0000 I0.0379 K-0.0951
    G3 X0.2280 Y1.5840 Z-0.0084 I-0.0010 K-0.0411
    G3 X0.2460 Y1.5840 Z-0.0122 I-0.0028 K-0.0586
    G3 X0.2640 Y1.5840 Z-0.0012 I0.0240 K-0.0191
    G1 X0.2820 Z-0.0006
     X0.2940 Z-0.0030
     X0.3120 Z-0.0004
     X0.3180 Z-0.0010
     X0.3300 Z-0.0061
     X0.3480 Z-0.0063
     X0.3660 Z-0.0114
    G3 X0.3780 Y1.5840 Z-0.0233 I-0.0167 K-0.0289
    G1 X0.3900 Z-0.0285
     X0.4020 Z-0.0259
     X0.4140 Z-0.0283
    G3 X0.4320 Y1.5840 Z-0.0214 I0.0190 K-0.0224
    G1 X0.4560 Z-0.0259
    G3 X0.4680 Y1.5840 Z-0.0362 I-0.0060 K-0.0191
    G2 X0.4800 Y1.5840 Z-0.1000 I1.9367 K0.3314
    G1 X0.9540
    F12.0000
    G0 Z0.0120
     X-0.1243 Y1.5360
    F12.0000
    G1 X0.0240
    G2 X0.0360 Y1.5360 Z-0.0152 I-0.3767 K0.0966
    G3 X0.0480 Y1.5360 Z-0.0050 I0.0240 K-0.0160
    G3 X0.0660 Y1.5360 Z0.0000 I0.0185 K-0.0318
    G1 X0.0840 Z-0.0030
    G3 X0.1020 Y1.5360 Z-0.0141 I-0.0072 K-0.0318
    G1 X0.1140 Z-0.0153
     X0.1260 Z-0.0143
    G3 X0.1380 Y1.5360 Z-0.0076 I0.0180 K-0.0181
    G1 X0.1500 Z-0.0057
     X0.1620 Z-0.0087
     X0.1800 Z-0.0086
     X0.1920 Z-0.0139
    G3 X0.2220 Y1.5360 Z-0.0043 I0.0347 K-0.0571
    G1 X0.2340 Z-0.0067
     X0.2520 Z-0.0145
     X0.2700 Z-0.0071
     X0.2880 Z-0.0053
     X0.3000 Z-0.0077
     X0.3120 Z-0.0055
     X0.3360 Z-0.0072
    G3 X0.3540 Y1.5360 Z-0.0174 I-0.0136 K-0.0449
    G1 X0.3600 Z-0.0268
    G3 X0.3720 Y1.5360 Z-0.0390 I-0.0245 K-0.0362
    G1 X0.3780 Z-0.0417
     X0.4020 Z-0.0763
    G2 X0.4200 Y1.5360 Z-0.0445 I-0.2028 K0.1359
    G3 X0.4500 Y1.5360 Z-0.0107 I0.3546 K-0.2842
    G3 X0.4620 Y1.5360 Z-0.0050 I0.0180 K-0.0226
    G2 X0.4800 Y1.5360 Z-0.0012 I-0.0032 K0.0597
    G1 X0.4920
    G3 X0.5160 Y1.5360 Z-0.0249 I-0.0060 K-0.0301
    G1 X0.5220 Z-0.0845
     X0.5280 Z-0.1000
     X0.9540
    F12.0000
    G0 Z0.0120
     X-0.0897 Y1.4880
    G2 X0.000000 Z-0.025954 R0.125000
    F12.0000
    G3 X0.0300 Y1.4880 Z-0.0153 I0.0872 K-0.1979
    G1 X0.0420
     X0.0540 Z-0.0205
     X0.0660 Z-0.0310
     X0.0720 Z-0.0332
    G3 X0.0960 Y1.4880 Z-0.0057 I0.0949 K-0.0585
    G3 X0.1140 Y1.4880 Z0.0000 I0.0180 K-0.0255
    G1 X0.1260 Z-0.0024
     X0.1440 Z-0.0125
     X0.1560
     X0.1620 Z-0.0156
     X0.1740 Z-0.0178
    G3 X0.1860 Y1.4880 Z-0.0245 I-0.0060 K-0.0248
    G1 X0.1920 Z-0.0259
    G3 X0.2160 Y1.4880 Z-0.0076 I0.0321 K-0.0173
    G1 X0.2280
     X0.2400 Z-0.0128
     X0.2460 Z-0.0131
    G3 X0.2580 Y1.4880 Z-0.0064 I0.0180 K-0.0181
    G1 X0.2760 Z-0.0033
     X0.2880
    G3 X0.3180 Y1.4880 Z-0.0249 I-0.0109 K-0.0468
    G3 X0.3360 Y1.4880 Z-0.0149 I0.0335 K-0.0391
    G3 X0.3480 Y1.4880 Z-0.0058 I0.0240 K-0.0191
    G1 X0.3600 Z-0.0033
    G3 X0.3780 Y1.4880 Z-0.0092 I-0.0000 K-0.0307
    G3 X0.3900 Y1.4880 Z-0.0234 I-0.0303 K-0.0377
    G2 X0.4020 Y1.4880 Z-0.0278 I0.0122 K0.0145
    G3 X0.4260 Y1.4880 Z-0.0149 I0.0371 K-0.0400
    G1 X0.4560 Z-0.0164
     X0.4680 Z-0.0132
    G3 X0.4800 Y1.4880 Z-0.0172 I-0.0000 K-0.0200
    G1 X0.4860 Z-0.0245
     X0.4980 Z-0.1000
     X0.9540
    F12.0000
    G0 Z0.0120
     X-0.0828 Y1.4400
    G2 X0.000000 Z-0.019361 R0.125000
    F12.0000
    G1 X0.0120
     X0.0300 Z-0.0286
     X0.0360 Z-0.0358
     X0.0420 Z-0.0590
    G3 X0.0540 Y1.4400 Z-0.0238 I0.0610 K-0.0012
    G3 X0.0780 Y1.4400 Z-0.0076 I0.0349 K-0.0259
    G1 X0.0900
     X0.0960 Z-0.0095
    G3 X0.1080 Y1.4400 Z-0.0183 I-0.0120 K-0.0289
    G3 X0.1200 Y1.4400 Z-0.0484 I-0.0761 K-0.0478
    G1 X0.1260 Z-0.0592
    G2 X0.1380 Y1.4400 Z-0.0401 I-0.0120 K0.0209
    G3 X0.1500 Y1.4400 Z-0.0298 I0.0180 K-0.0087
    G1 X0.1740 Z-0.0261
     X0.1860 Z-0.0291
    G3 X0.1980 Y1.4400 Z-0.0429 I-0.0120 K-0.0226
    G2 X0.2100 Y1.4400 Z-0.1000 I0.2730 K0.0276
    G1 X0.2640
     X0.2700 Z-0.0849
    G3 X0.2820 Y1.4400 Z-0.0303 I0.3042 K-0.0384
    G1 X0.2880 Z-0.0231
     X0.3060 Z-0.0117
     X0.3180 Z-0.0091
    G3 X0.3420 Y1.4400 Z-0.0186 I-0.0009 K-0.0373
    G1 X0.3540 Z-0.0309
    G3 X0.3780 Y1.4400 Z-0.0157 I0.0383 K-0.0338
    G1 X0.3900
    G3 X0.4080 Y1.4400 Z-0.0237 I-0.0138 K-0.0554
    G3 X0.4200 Y1.4400 Z-0.0421 I-0.0180 K-0.0248
    G1 X0.4260 Z-0.1000
     X0.9540
    F12.0000
    G0 Z0.0120
     X-0.0862 Y1.3920
    G2 X0.000000 Z-0.022500 R0.125000
    F12.0000
    G3 X0.0120 Y1.3920 Z-0.0087 I0.0240 K-0.0088
    G3 X0.0360 Y1.3920 Z-0.0022 I0.0266 K-0.0501
    G1 X0.0480 Z-0.0046
    G3 X0.0660 Y1.3920 Z-0.0185 I-0.0245 K-0.0503
    G1 X0.1080 Z-0.0195
     X0.1200 Z-0.0246
     X0.1320 Z-0.0217
     X0.1500 Z-0.0207
     X0.1680 Z-0.0165
     X0.1800
     X0.1920 Z-0.0141
     X0.2040 Z-0.0165
     X0.2220 Z-0.0169
     X0.2340 Z-0.0219
     X0.2400 Z-0.0227
    G3 X0.2580 Y1.3920 Z-0.0181 I0.0196 K-0.0394
    G3 X0.2760 Y1.3920 Z-0.0220 I-0.0029 K-0.0560
    G1 X0.2820 Z-0.0198
     X0.3000 Z-0.0191
    G3 X0.3120 Y1.3920 Z-0.0231 I-0.0000 K-0.0200
    G3 X0.3360 Y1.3920 Z-0.0129 I0.0248 K-0.0254
    G3 X0.3660 Y1.3920 Z-0.0305 I-0.0004 K-0.0350
    G1 X0.3720 Z-0.0582
     X0.3780 Z-0.0262
    G3 X0.3900 Y1.3920 Z-0.0160 I0.0240 K-0.0160
    G1 X0.3960 Z-0.0140
     X0.4080 Z-0.0131
    G3 X0.4260 Y1.3920 Z-0.0177 I-0.0011 K-0.0420
    G3 X0.4380 Y1.3920 Z-0.0315 I-0.0120 K-0.0226
    G1 X0.4440 Z-0.0915
     X0.4500 Z-0.1000
     X0.9540
    F12.0000
    G0 Z0.0120
     X-0.1243 Y1.3440
    F12.0000
    G1 X0.0360
    G3 X0.0480 Y1.3440 Z-0.0347 I0.4587 K-0.0505
    G1 X0.0720 Z-0.0277
     X0.0960 Z-0.0336
     X0.1020 Z-0.0333
    G3 X0.1140 Y1.3440 Z-0.0293 I0.0120 K-0.0160
    G1 X0.1260 Z-0.0294
    G3 X0.1380 Y1.3440 Z-0.0376 I-0.0114 K-0.0296
    G1 X0.1500 Z-0.0406
     X0.1560 Z-0.0539
    G2 X0.1680 Y1.3440 Z-0.1000 I0.2701 K0.0457
    G1 X0.3120
     X0.3180 Z-0.0872
     X0.3240 Z-0.0278
     X0.3300 Z-0.0212
    G3 X0.3540 Y1.3440 Z-0.0127 I0.0263 K-0.0360
    G3 X0.3720 Y1.3440 Z-0.0186 I-0.0000 K-0.0307
    G3 X0.3840 Y1.3440 Z-0.0370 I-0.0180 K-0.0248
    G1 X0.3900 Z-0.0766
     X0.3960 Z-0.0262
    G3 X0.4260 Y1.3440 Z-0.0102 I0.0315 K-0.0229
    G3 X0.4560 Y1.3440 Z-0.0327 I0.0000 K-0.0312
    G1 X0.4620 Z-0.0825
     X0.4680 Z-0.1000
     X0.9540
    F12.0000
    G0 Z0.0120
     X-0.1243 Y1.2960
    F12.0000
    G1 X0.3300
     X0.3360 Z-0.0398
    G3 X0.3480 Y1.2960 Z-0.0198 I0.0277 K-0.0031
    G1 X0.3600 Z-0.0147
     X0.3720
    G3 X0.3900 Y1.2960 Z-0.0254 I-0.0060 K-0.0307
    G1 X0.3960 Z-0.0366
     X0.4020 Z-0.0802
     X0.4080 Z-0.0684
     X0.4140 Z-0.0274
    G3 X0.4260 Y1.2960 Z-0.0172 I0.0240 K-0.0160
    G1 X0.4440 Z-0.0139
    G3 X0.4740 Y1.2960 Z-0.0382 I-0.0000 K-0.0307
    G1 X0.4800 Z-0.0994
     X0.9540 Z-0.1000
    F12.0000
    G0 Z0.0120
     X-0.1243 Y1.2480
    F12.0000
    G1 X0.3420
    G3 X0.3540 Y1.2480 Z-0.0285 I0.2556 K-0.0061
    G3 X0.3780 Y1.2480 Z-0.0173 I0.0240 K-0.0200
    G3 X0.4080 Y1.2480 Z-0.0398 I0.0000 K-0.0312
    G2 X0.4200 Y1.2480 Z-0.1000 I0.2691 K0.0223
    G1 X0.4260 Z-0.0464
     X0.4320 Z-0.0275
    G3 X0.4560 Y1.2480 Z-0.0159 I0.0240 K-0.0191
    G3 X0.4860 Y1.2480 Z-0.0321 I-0.0006 K-0.0370
    G3 X0.4980 Y1.2480 Z-0.1000 I-0.2469 K-0.0786
    G1 X0.9540
    F12.0000
    G0 Z0.0120
     X-0.1243 Y1.2000
    F12.0000
    G1 X0.3540
     X0.3600 Z-0.0460
     X0.3660 Z-0.0269
    G3 X0.3900 Y1.2000 Z-0.0157 I0.0240 K-0.0200
    G3 X0.4200 Y1.2000 Z-0.0382 I0.0000 K-0.0312
    G1 X0.4260 Z-0.0970
     X0.4320 Z-0.1000
    G2 X0.4440 Y1.2000 Z-0.0313 I-0.6141 K0.1427
    G3 X0.4680 Y1.2000 Z-0.0185 I0.0240 K-0.0160
    G1 X0.4860 Z-0.0215
    G3 X0.4980 Y1.2000 Z-0.0306 I-0.0120 K-0.0282
    G1 X0.5040 Z-0.0433
     X0.5100 Z-0.1000
     X0.9540
    F12.0000
    G0 Z0.0120
     X-0.1243 Y1.1520
    F12.0000
    G1 X0.3600
     X0.3660 Z-0.0978
     X0.3720 Z-0.0325
    G3 X0.3960 Y1.1520 Z-0.0197 I0.0240 K-0.0160
    G1 X0.4080 Z-0.0203
     X0.4140 Z-0.0223
    G3 X0.4260 Y1.1520 Z-0.0325 I-0.0120 K-0.0262
    G1 X0.4320 Z-0.0504
     X0.4380 Z-0.1000
     X0.4440
    G2 X0.4560 Y1.1520 Z-0.0309 I-0.2169 K0.0733
    G3 X0.4800 Y1.1520 Z-0.0181 I0.0240 K-0.0160
    G1 X0.4980 Z-0.0211
    G3 X0.5100 Y1.1520 Z-0.0310 I-0.0133 K-0.0284
    G1 X0.5160 Z-0.0437
     X0.5220 Z-0.1000
     X0.9540
    F12.0000
    G0 Z0.0120
     X-0.1243 Y1.1040
    F12.0000
    G1 X0.3720
    G3 X0.3840 Y1.1040 Z-0.0278 I0.3048 K-0.0136
    G3 X0.4080 Y1.1040 Z-0.0163 I0.0240 K-0.0191
    G3 X0.4380 Y1.1040 Z-0.0405 I-0.0000 K-0.0307
    G1 X0.4440 Z-0.1000
     X0.4560
    G2 X0.4680 Y1.1040 Z-0.0298 I-0.4470 K0.1125
    G3 X0.4920 Y1.1040 Z-0.0181 I0.0244 K-0.0195
    G3 X0.5220 Y1.1040 Z-0.0337 I-0.0010 K-0.0387
    G1 X0.5280 Z-0.0512
     X0.5340 Z-0.1000
     X0.9540
    F12.0000
    G0 Z0.0120
     X-0.1243 Y1.0560
    F12.0000
    G1 X0.3780
    G2 X0.3900 Y1.0560 Z-0.0273 I-1.4721 K0.2804
    G3 X0.4140 Y1.0560 Z-0.0161 I0.0240 K-0.0200
    G3 X0.4440 Y1.0560 Z-0.0386 I0.0000 K-0.0312
    G1 X0.4500 Z-0.1000
     X0.4680
    G3 X0.4800 Y1.0560 Z-0.0286 I0.6680 K-0.0756
    G3 X0.5040 Y1.0560 Z-0.0171 I0.0240 K-0.0191
    G3 X0.5340 Y1.0560 Z-0.0401 I-0.0000 K-0.0311
    G3 X0.5460 Y1.0560 Z-0.1000 I-1.1193 K-0.2555
    G1 X0.9540
    F12.0000
    G0 Z0.0120
     X-0.1243 Y1.0080
    F12.0000
    G1 X0.3840
     X0.3900 Z-0.0502
    G3 X0.4200 Y1.0080 Z-0.0304 I0.0312 K-0.0147
    G3 X0.4440 Y1.0080 Z-0.0420 I-0.0000 K-0.0307
    G1 X0.4500 Z-0.0547
     X0.4560 Z-0.1000
     X0.4800
     X0.4860 Z-0.0417
    G3 X0.4980 Y1.0080 Z-0.0221 I0.0292 K-0.0044
    G3 X0.5160 Y1.0080 Z-0.0163 I0.0180 K-0.0248
    G3 X0.5400 Y1.0080 Z-0.0278 I-0.0000 K-0.0307
    G1 X0.5460 Z-0.0406
     X0.5520 Z-0.0939
     X0.5580 Z-0.1000
     X0.9540
    F12.0000
    G0 Z0.0120
     X-0.1243 Y0.9600
    F12.0000
    G1 X0.3840
    G2 X0.3960 Y0.9600 Z-0.0297 I-0.5118 K0.1235
    G3 X0.4200 Y0.9600 Z-0.0182 I0.0241 K-0.0196
    G3 X0.4500 Y0.9600 Z-0.0409 I-0.0001 K-0.0312
    G1 X0.4560 Z-0.1000
     X0.4860
     X0.4920 Z-0.0860
     X0.4980 Z-0.0301
    G3 X0.5220 Y0.9600 Z-0.0173 I0.0240 K-0.0160
    G3 X0.5520 Y0.9600 Z-0.0360 I-0.0006 K-0.0343
    G3 X0.5640 Y0.9600 Z-0.1000 I-0.1858 K-0.0680
    G1 X0.9540
    F12.0000
    G0 Z0.0120
     X-0.1243 Y0.9120
    F12.0000
    G1 X0.3840
    G2 X0.3960 Y0.9120 Z-0.0301 I-0.5308 K0.1271
    G3 X0.4200 Y0.9120 Z-0.0188 I0.0240 K-0.0200
    G3 X0.4500 Y0.9120 Z-0.0413 I0.0000 K-0.0312
    G1 X0.4560 Z-0.1000
     X0.4980
     X0.5040 Z-0.0468
     X0.5100 Z-0.0271
    G3 X0.5340 Y0.9120 Z-0.0155 I0.0240 K-0.0191
    G3 X0.5580 Y0.9120 Z-0.0271 I-0.0000 K-0.0307
    G1 X0.5640 Z-0.0398
     X0.5700 Z-0.0966
     X0.5760 Z-0.1000
     X0.9540
    F12.0000
    G0 Z0.0120
     X-0.1243 Y0.8640
    F12.0000
    G1 X0.3840
     X0.3900 Z-0.0557
     X0.3960 Z-0.0408
    G3 X0.4200 Y0.8640 Z-0.0292 I0.0240 K-0.0191
    G3 X0.4500 Y0.8640 Z-0.0523 I-0.0000 K-0.0311
    G1 X0.4560 Z-0.1000
     X0.5040
     X0.5100 Z-0.0837
     X0.5160 Z-0.0286
    G3 X0.5400 Y0.8640 Z-0.0171 I0.0240 K-0.0191
    G3 X0.5640 Y0.8640 Z-0.0286 I-0.0000 K-0.0307
    G1 X0.5700 Z-0.0414
    G3 X0.5820 Y0.8640 Z-0.1000 I-0.5017 K-0.1332
    G1 X0.9540
    F12.0000
    G0 Z0.0120
     X-0.1243 Y0.8160
    F12.0000
    G1 X0.3780
     X0.3840 Z-0.0988
     X0.3900 Z-0.0369
    G3 X0.4140 Y0.8160 Z-0.0251 I0.0244 K-0.0195
    G3 X0.4380 Y0.8160 Z-0.0369 I-0.0002 K-0.0309
    G1 X0.4440 Z-0.0496
     X0.4560 Z-0.1000
     X0.5160
     X0.5220 Z-0.0394
    G3 X0.5520 Y0.8160 Z-0.0185 I0.0319 K-0.0138
    G3 X0.5760 Y0.8160 Z-0.0313 I-0.0000 K-0.0289
    G1 X0.5820 Z-0.0457
     X0.5880 Z-0.1000
     X0.9540
    F12.0000
    G0 Z0.0120
     X-0.1243 Y0.7680
    F12.0000
    G1 X0.3780
     X0.3840 Z-0.0871
     X0.3900 Z-0.0273
    G3 X0.4140 Y0.7680 Z-0.0159 I0.0241 K-0.0196
    G3 X0.4440 Y0.7680 Z-0.0386 I-0.0001 K-0.0312
    G1 X0.4500 Z-0.1000
     X0.5220
    G3 X0.5340 Y0.7680 Z-0.0277 I0.6134 K-0.0647
    G3 X0.5580 Y0.7680 Z-0.0165 I0.0240 K-0.0200
    G3 X0.5880 Y0.7680 Z-0.0390 I0.0000 K-0.0312
    G1 X0.5940 Z-0.0994
     X0.9540 Z-0.1000
    F12.0000
    G0 Z0.0120
     X-0.1243 Y0.7200
    F12.0000
    G1 X0.3780
    G2 X0.3900 Y0.7200 Z-0.0324 I-0.3335 K0.0941
    G3 X0.4140 Y0.7200 Z-0.0212 I0.0240 K-0.0200
    G3 X0.4440 Y0.7200 Z-0.0437 I0.0000 K-0.0312
    G1 X0.4500 Z-0.1000
     X0.5280
     X0.5340 Z-0.0782
     X0.5400 Z-0.0242
    G3 X0.5640 Y0.7200 Z-0.0129 I0.0240 K-0.0200
    G3 X0.5880 Y0.7200 Z-0.0205 I-0.0010 K-0.0447
    G1 X0.6000 Z-0.0207
     X0.6060 Z-0.0227
     X0.6240 Z-0.0225
    G3 X0.6480 Y0.7200 Z-0.0321 I-0.0205 K-0.0860
    G1 X0.6540 Z-0.0394
    G2 X0.6660 Y0.7200 Z-0.1000 I1.3142 K0.2286
    G1 X0.9540
    F12.0000
    G0 Z0.0120
     X-0.1243 Y0.6720
    F12.0000
    G1 X0.3780
    G2 X0.3900 Y0.6720 Z-0.0324 I-0.4992 K0.1235
    G3 X0.4140 Y0.6720 Z-0.0212 I0.0240 K-0.0200
    G3 X0.4440 Y0.6720 Z-0.0437 I0.0000 K-0.0312
    G1 X0.4500 Z-0.1000
     X0.5820
     X0.5880 Z-0.0939
     X0.6060 Z-0.0437
     X0.6180 Z-0.0294
    G3 X0.6300 Y0.6720 Z-0.0252 I0.0130 K-0.0179
    G1 X0.6540 Z-0.0077
     X0.6840 Z-0.0018
    G3 X0.7080 Y0.6720 Z-0.0126 I-0.0002 K-0.0323
    G1 X0.7140 Z-0.0192
    G2 X0.7260 Y0.6720 Z-0.0421 I0.0596 K0.0165
    G1 X0.7320 Z-0.1000
     X0.8340
     X0.8400 Z-0.0547
    G3 X0.8580 Y0.6720 Z-0.0152 I0.0785 K-0.0120
    G1 X0.8640 Z-0.0122
     X0.8760
    G3 X0.8880 Y0.6720 Z-0.0225 I-0.0060 K-0.0191
    G1 X0.8940 Z-0.0343
     X0.9000 Z-0.0884
    G3 X0.9120 Y0.6720 Z-0.0280 I0.2046 K-0.0093
    G3 X0.9300 Y0.6720 Z-0.0103 I0.0524 K-0.0353
    G1 X0.9420 Z-0.0073
     X0.9540 Z-0.0103
    F12.0000
    G0 Z0.0120
     X-0.1243 Y0.6240
    F12.0000
    G1 X0.3780
     X0.3840 Z-0.0913
     X0.3900 Z-0.0309
    G3 X0.4140 Y0.6240 Z-0.0181 I0.0240 K-0.0160
    G3 X0.4380 Y0.6240 Z-0.0309 I-0.0000 K-0.0289
    G1 X0.4440 Z-0.0433
    G2 X0.4560 Y0.6240 Z-0.1000 I0.1485 K0.0018
    G1 X0.6780
     X0.6840 Z-0.0390
    G3 X0.6960 Y0.6240 Z-0.0286 I0.0180 K-0.0087
    G2 X0.7260 Y0.6240 Z-0.0148 I-0.0424 K0.1315
    G1 X0.7380 Z-0.0122
    G3 X0.7560 Y0.6240 Z-0.0169 I-0.0014 K-0.0417
    G3 X0.7680 Y0.6240 Z-0.0307 I-0.0120 K-0.0226
    G1 X0.7740 Z-0.0872
     X0.7800 Z-0.1000
     X0.8340
     X0.8400 Z-0.0815
     X0.8460 Z-0.0225
    G3 X0.8580 Y0.6240 Z-0.0087 I0.0240 K-0.0088
    G1 X0.8880 Z-0.0024
    G3 X0.9060 Y0.6240 Z-0.0087 I-0.0000 K-0.0289
    G1 X0.9120 Z-0.0095
     X0.9240 Z-0.0065
     X0.9360 Z-0.0092
     X0.9480 Z-0.0099
     X0.9540 Z-0.0122
    F12.0000
    G0 Z0.0120
     X-0.1243 Y0.5760
    F12.0000
    G1 X0.3840
     X0.3900 Z-0.0801
     X0.3960 Z-0.0290
    G3 X0.4200 Y0.5760 Z-0.0174 I0.0240 K-0.0191
    G3 X0.4380 Y0.5760 Z-0.0215 I-0.0020 K-0.0512
    G3 X0.4500 Y0.5760 Z-0.0317 I-0.0120 K-0.0262
    G3 X0.4620 Y0.5760 Z-0.1000 I-0.3080 K-0.0893
    G1 X0.7200
    G3 X0.7320 Y0.5760 Z-0.0274 I0.3180 K-0.0153
    G3 X0.7440 Y0.5760 Z-0.0172 I0.0240 K-0.0160
    G1 X0.7680 Z-0.0120
    G3 X0.7980 Y0.5760 Z-0.0363 I-0.0000 K-0.0307
    G1 X0.8040 Z-0.1000
     X0.8280
     X0.8340 Z-0.0900
     X0.8400 Z-0.0386
     X0.8460 Z-0.0195
    G3 X0.8580 Y0.5760 Z-0.0093 I0.0240 K-0.0160
    G3 X0.8760 Y0.5760 Z-0.0040 I0.0187 K-0.0298
    G1 X0.8880 Z-0.0066
     X0.9000 Z-0.0049
     X0.9120 Z-0.0053
    G3 X0.9360 Y0.5760 Z-0.0201 I-0.0095 K-0.0423
    G3 X0.9480 Y0.5760 Z-0.0243 I-0.0010 K-0.0221
    G1 X0.9540 Z-0.0308
    F12.0000
    G0 Z0.0120
     X-0.1243 Y0.5280
    F12.0000
    G1 X0.3960
    G2 X0.4080 Y0.5280 Z-0.0294 I-0.2641 K0.0812
    G1 X0.4140 Z-0.0122
    G3 X0.4380 Y0.5280 Z-0.0006 I0.0240 K-0.0191
    G3 X0.4620 Y0.5280 Z-0.0122 I-0.0000 K-0.0307
    G2 X0.4740 Y0.5280 Z-0.0358 I0.2012 K0.0871
    G1 X0.4800 Z-0.1000
     X0.4920
    G3 X0.5040 Y0.5280 Z-0.0723 I0.2068 K-0.0732
    G3 X0.5220 Y0.5280 Z-0.0610 I0.0180 K-0.0088
    G3 X0.5400 Y0.5280 Z-0.0723 I-0.0000 K-0.0200
    G1 X0.5460 Z-0.1000
     X0.7440
     X0.7500 Z-0.0450
     X0.7560 Z-0.0267
     X0.7620 Z-0.0209
    G3 X0.7800 Y0.5280 Z-0.0132 I0.0191 K-0.0198
    G3 X0.7920 Y0.5280 Z-0.0172 I-0.0000 K-0.0200
    G1 X0.8280 Z-0.0184
     X0.8340 Z-0.0169
     X0.8460 Z-0.0085
     X0.8580 Z-0.0061
    G3 X0.8880 Y0.5280 Z-0.0231 I-0.0005 K-0.0359
    G1 X0.8940 Z-0.0421
     X0.9000 Z-0.1000
     X0.9540
    F12.0000
    G0 Z0.0120
     X-0.1243 Y0.4800
    F12.0000
    G1 X0.3960
     X0.4020 Z-0.0906
     X0.4080 Z-0.0314
    G3 X0.4320 Y0.4800 Z-0.0198 I0.0240 K-0.0191
    G3 X0.4500 Y0.4800 Z-0.0050 I0.0387 K-0.0288
    G1 X0.4620 Z-0.0024
     X0.4920 Z-0.0046
    G3 X0.5100 Y0.4800 Z-0.0168 I-0.0060 K-0.0282
    G1 X0.5220 Z-0.0180
     X0.5280 Z-0.0211
    G3 X0.5460 Y0.4800 Z-0.0464 I-0.1132 K-0.0996
    G3 X0.5580 Y0.4800 Z-0.1000 I-0.1992 K-0.0728
    G1 X0.5820
     X0.5880 Z-0.0395
    G3 X0.6120 Y0.4800 Z-0.0241 I0.0243 K-0.0115
    G1 X0.6240 Z-0.0271
    G3 X0.6420 Y0.4800 Z-0.0396 I-0.0153 K-0.0413
    G1 X0.6480 Z-0.0523
     X0.6540 Z-0.1000
     X0.6600
    G3 X0.6720 Y0.4800 Z-0.0358 I0.1781 K-0.0001
    G3 X0.6900 Y0.4800 Z-0.0246 I0.0180 K-0.0087
    G3 X0.7080 Y0.4800 Z-0.0358 I0.0000 K-0.0200
    G3 X0.7200 Y0.4800 Z-0.0931 I-0.1698 K-0.0655
    G1 X0.7260 Z-0.1000
     X0.7440
    G2 X0.7560 Y0.4800 Z-0.0332 I-0.5619 K0.1354
    G1 X0.7680 Z-0.0172
    G3 X0.7800 Y0.4800 Z-0.0132 I0.0120 K-0.0160
    G3 X0.7920 Y0.4800 Z-0.0172 I-0.0000 K-0.0200
    G3 X0.8100 Y0.4800 Z-0.0445 I-0.0789 K-0.0716
    G2 X0.8220 Y0.4800 Z-0.1000 I0.2503 K0.0250
    G1 X0.9540
    F12.0000
    G0 Z0.0120
     X-0.1243 Y0.4320
    F12.0000
    G1 X0.3960
     X0.4020 Z-0.0873
     X0.4080 Z-0.0277
    G3 X0.4320 Y0.4320 Z-0.0165 I0.0240 K-0.0200
    G3 X0.4620 Y0.4320 Z-0.0390 I0.0000 K-0.0312
    G1 X0.4680 Z-0.0962
     X0.4740 Z-0.1000
     X0.4860 Z-0.0394
     X0.4920 Z-0.0207
    G3 X0.5160 Y0.4320 Z-0.0061 I0.0246 K-0.0134
    G3 X0.5400 Y0.4320 Z-0.0207 I-0.0002 K-0.0274
    G1 X0.5460 Z-0.0370
     X0.5520 Z-0.0864
     X0.5580 Z-0.1000
     X0.5760
     X0.5820 Z-0.0356
    G3 X0.5940 Y0.4320 Z-0.0135 I0.0285 K-0.0011
    G3 X0.6120 Y0.4320 Z-0.0076 I0.0180 K-0.0248
    G1 X0.6240 Z-0.0100
     X0.6360
     X0.6540 Z-0.0167
     X0.6720 Z-0.0034
     X0.6840 Z-0.0010
    G3 X0.7140 Y0.4320 Z-0.0253 I-0.0000 K-0.0307
    G3 X0.7260 Y0.4320 Z-0.1000 I-4.8326 K-0.8144
    G1 X0.7440
     X0.7500 Z-0.0372
    G3 X0.7740 Y0.4320 Z-0.0234 I0.0250 K-0.0156
    G3 X0.7980 Y0.4320 Z-0.0372 I-0.0003 K-0.0283
    G3 X0.8160 Y0.4320 Z-0.1000 I-0.1019 K-0.0632
    G1 X0.9540
    F12.0000
    G0 Z0.0120
     X-0.1243 Y0.3840
    F12.0000
    G1 X0.3960
     X0.4020 Z-0.0976
     X0.4080 Z-0.0376
     X0.4140 Z-0.0319
    G3 X0.4320 Y0.3840 Z-0.0261 I0.0180 K-0.0248
    G3 X0.4500 Y0.3840 Z-0.0319 I-0.0000 K-0.0307
    G1 X0.4560 Z-0.0376
    G3 X0.4680 Y0.3840 Z-0.0672 I-0.1412 K-0.0745
    G1 X0.4740 Z-0.0401
     X0.4800 Z-0.0308
     X0.4980 Z-0.0091
    G3 X0.5160 Y0.3840 Z-0.0028 I0.0180 K-0.0226
    G3 X0.5400 Y0.3840 Z-0.0156 I-0.0000 K-0.0289
    G3 X0.5520 Y0.3840 Z-0.0880 I-0.2158 K-0.0730
    G1 X0.5580 Z-0.1000
     X0.5640
     X0.5700 Z-0.0433
     X0.5760 Z-0.0269
    G3 X0.6000 Y0.3840 Z-0.0157 I0.0240 K-0.0200
    G1 X0.6120 Z-0.0181
     X0.6300 Z-0.0314
     X0.6420 Z-0.0366
    G3 X0.6540 Y0.3840 Z-0.0533 I-0.0204 K-0.0274
    G1 X0.6600 Z-0.0289
     X0.6660 Z-0.0234
    G3 X0.6840 Y0.3840 Z-0.0176 I0.0180 K-0.0255
    G3 X0.7020 Y0.3840 Z-0.0234 I0.0000 K-0.0312
    G3 X0.7140 Y0.3840 Z-0.0401 I-0.0180 K-0.0255
    G1 X0.7200 Z-0.0947
     X0.7260 Z-0.1000
     X0.7320
    G3 X0.7440 Y0.3840 Z-0.0286 I0.3988 K-0.0304
    G3 X0.7680 Y0.3840 Z-0.0171 I0.0240 K-0.0191
    G3 X0.7920 Y0.3840 Z-0.0286 I-0.0000 K-0.0307
    G1 X0.7980 Z-0.0405
    G2 X0.8100 Y0.3840 Z-0.1000 I0.4314 K0.0561
    G1 X0.9540
    F12.0000
    G0 Z0.0120
     X-0.1243 Y0.3360
    F12.0000
    G1 X0.4020
     X0.4080 Z-0.0799
     X0.4140 Z-0.0294
    G3 X0.4260 Y0.3360 Z-0.0203 I0.0240 K-0.0191
    G1 X0.4320 Z-0.0184
     X0.4440
     X0.4560 Z-0.0237
     X0.4620 Z-0.0225
    G3 X0.4740 Y0.3360 Z-0.0140 I0.0278 K-0.0264
    G1 X0.4800 Z-0.0122
     X0.4920
    G3 X0.5160 Y0.3360 Z-0.0282 I-0.0088 K-0.0390
    G1 X0.5280 Z-0.0285
    G3 X0.5400 Y0.3360 Z-0.0342 I-0.0060 K-0.0282
    G3 X0.5520 Y0.3360 Z-0.0543 I-0.0237 K-0.0278
    G1 X0.5580 Z-0.0262
    G3 X0.5700 Y0.3360 Z-0.0160 I0.0240 K-0.0160
    G1 X0.5820 Z-0.0134
     X0.5940 Z-0.0137
    G3 X0.6120 Y0.3360 Z-0.0221 I-0.0118 K-0.0488
    G1 X0.6240 Z-0.0169
     X0.6360
    G3 X0.6540 Y0.3360 Z-0.0278 I-0.0060 K-0.0301
    G3 X0.6840 Y0.3360 Z-0.0047 I0.0314 K-0.0098
    G3 X0.7080 Y0.3360 Z-0.0176 I-0.0000 K-0.0289
    G3 X0.7200 Y0.3360 Z-0.0790 I-0.2985 K-0.0902
    G1 X0.7260 Z-0.0358
     X0.7320 Z-0.0246
    G3 X0.7560 Y0.3360 Z-0.0133 I0.0240 K-0.0200
    G3 X0.7860 Y0.3360 Z-0.0358 I0.0000 K-0.0312
    G2 X0.7980 Y0.3360 Z-0.1000 I0.3846 K0.0387
    G1 X0.9540
    F12.0000
    G0 Z0.0120
     X-0.1243 Y0.2880
    F12.0000
    G1 X0.4020
     X0.4080 Z-0.0438
     X0.4140 Z-0.0243
    G3 X0.4260 Y0.2880 Z-0.0140 I0.0240 K-0.0160
    G1 X0.4380 Z-0.0114
     X0.4440 Z-0.0120
     X0.4620 Z-0.0191
     X0.4680 Z-0.0171
     X0.4800
    G3 X0.4980 Y0.2880 Z-0.0269 I-0.0097 K-0.0395
    G1 X0.5040 Z-0.0263
    G3 X0.5160 Y0.2880 Z-0.0207 I0.0180 K-0.0226
    G1 X0.5280
     X0.5340 Z-0.0227
     X0.5400 Z-0.0216
    G3 X0.5520 Y0.2880 Z-0.0124 I0.0240 K-0.0191
    G1 X0.5700 Z-0.0092
    G3 X0.6000 Y0.2880 Z-0.0335 I-0.0000 K-0.0307
    G1 X0.6060 Z-0.0333
    G3 X0.6300 Y0.2880 Z-0.0161 I0.0341 K-0.0222
    G1 X0.6420
     X0.6540 Z-0.0213
    G2 X0.6780 Y0.2880 Z-0.0122 I-0.0120 K0.0675
    G1 X0.6840 Z-0.0112
    G3 X0.6960 Y0.2880 Z-0.0152 I-0.0000 K-0.0200
    G1 X0.7080 Z-0.0237
     X0.7140 Z-0.0235
    G3 X0.7320 Y0.2880 Z-0.0125 I0.0240 K-0.0191
    G1 X0.7440
     X0.7560 Z-0.0168
    G3 X0.7740 Y0.2880 Z-0.0386 I-0.0120 K-0.0282
    G1 X0.7800 Z-0.1000
     X0.9540
    F12.0000
    G0 Z0.0120
     X-0.1243 Y0.2400
    F12.0000
    G1 X0.4020
     X0.4080 Z-0.0511
     X0.4140 Z-0.0265
     X0.4200 Z-0.0210
     X0.4320 Z-0.0159
     X0.4440
     X0.4560 Z-0.0210
     X0.4680 Z-0.0208
     X0.4800 Z-0.0234
    G3 X0.4920 Y0.2400 Z-0.0325 I-0.0120 K-0.0282
    G3 X0.5220 Y0.2400 Z-0.0122 I0.0306 K-0.0128
    G1 X0.5280 Z-0.0127
     X0.5460 Z-0.0191
     X0.5580 Z-0.0167
     X0.5700 Z-0.0191
    G3 X0.5880 Y0.2400 Z-0.0337 I-0.0209 K-0.0443
    G1 X0.5940 Z-0.0472
     X0.6000 Z-0.1000
    G2 X0.6120 Y0.2400 Z-0.0298 I-0.2763 K0.0834
    G1 X0.6180 Z-0.0241
     X0.6300 Z-0.0187
     X0.6360 Z-0.0181
     X0.6540 Z-0.0207
     X0.6600 Z-0.0187
     X0.6720
    G3 X0.6900 Y0.2400 Z-0.0135 I0.0185 K-0.0303
    G3 X0.7080 Y0.2400 Z-0.0194 I0.0000 K-0.0307
    G3 X0.7320 Y0.2400 Z-0.0112 I0.0283 K-0.0438
    G3 X0.7560 Y0.2400 Z-0.0227 I-0.0000 K-0.0307
    G3 X0.7680 Y0.2400 Z-0.0515 I-0.1662 K-0.0861
    G1 X0.7740 Z-0.1000
     X0.9540
    F12.0000
    G0 Z0.0120
     X-0.1243 Y0.1920
    F12.0000
    G1 X0.3900
    G3 X0.4020 Y0.1920 Z-0.0267 I0.3404 K-0.0181
    G3 X0.4260 Y0.1920 Z-0.0151 I0.0240 K-0.0191
    G3 X0.4440 Y0.1920 Z-0.0199 I-0.0009 K-0.0394
    G1 X0.4560 Z-0.0174
     X0.4680 Z-0.0199
    G3 X0.4860 Y0.1920 Z-0.0405 I-0.0125 K-0.0290
    G3 X0.5100 Y0.1920 Z-0.0203 I0.0335 K-0.0153
    G1 X0.5280 Z-0.0195
     X0.5460 Z-0.0163
     X0.5580 Z-0.0187
    G3 X0.5760 Y0.1920 Z-0.0406 I-0.0120 K-0.0282
    G3 X0.5880 Y0.1920 Z-0.1000 I-1.5271 K-0.3393
    G2 X0.6000 Y0.1920 Z-0.0294 I-2.7805 K0.5086
    G3 X0.6180 Y0.1920 Z-0.0171 I0.0240 K-0.0160
    G1 X0.6240 Z-0.0165
     X0.6420 Z-0.0187
     X0.6540 Z-0.0163
    G3 X0.6720 Y0.1920 Z-0.0221 I-0.0000 K-0.0307
    G1 X0.6780 Z-0.0227
     X0.6900 Z-0.0200
     X0.7020 Z-0.0227
    G3 X0.7200 Y0.1920 Z-0.0171 I0.0186 K-0.0281
    G3 X0.7380 Y0.1920 Z-0.0229 I-0.0000 K-0.0307
    G3 X0.7500 Y0.1920 Z-0.0405 I-0.0189 K-0.0257
    G2 X0.7620 Y0.1920 Z-0.1000 I1.7859 K0.3295
    G1 X0.9540
    F12.0000
    G0 Z0.0120
     X-0.1243 Y0.1440
    F12.0000
    G1 X0.3720
     X0.3780 Z-0.0919
     X0.3840 Z-0.0333
    G3 X0.4140 Y0.1440 Z-0.0133 I0.0308 K-0.0138
    G3 X0.4320 Y0.1440 Z-0.0175 I-0.0016 K-0.0473
    G1 X0.4440 Z-0.0173
     X0.4560 Z-0.0199
    G3 X0.4740 Y0.1440 Z-0.0421 I-0.0134 K-0.0293
    G3 X0.4920 Y0.1440 Z-0.0195 I0.0347 K-0.0092
    G1 X0.4980 Z-0.0175
     X0.5220 Z-0.0168
     X0.5340 Z-0.0143
     X0.5460 Z-0.0168
    G3 X0.5640 Y0.1440 Z-0.0341 I-0.0151 K-0.0337
    G2 X0.5760 Y0.1440 Z-0.0727 I0.0807 K0.0039
    G1 X0.5820 Z-0.0262
    G3 X0.5940 Y0.1440 Z-0.0160 I0.0240 K-0.0160
    G1 X0.6060 Z-0.0134
     X0.6240 Z-0.0165
     X0.6420 Z-0.0137
    G3 X0.6600 Y0.1440 Z-0.0194 I0.0000 K-0.0312
    G3 X0.6780 Y0.1440 Z-0.0151 I0.0195 K-0.0413
    G1 X0.6900 Z-0.0175
     X0.7080 Z-0.0147
     X0.7140 Z-0.0153
    G3 X0.7380 Y0.1440 Z-0.0325 I-0.0080 K-0.0365
    G3 X0.7500 Y0.1440 Z-0.1000 I-0.1926 K-0.0690
    G1 X0.9540
    F12.0000
    G0 Z0.0120
     X-0.1243 Y0.0960
    F12.0000
    G1 X0.3240
     X0.3300 Z-0.0405
    G3 X0.3420 Y0.0960 Z-0.0236 I0.0439 K-0.0184
    G1 X0.3660 Z-0.0118
     X0.3780 Z-0.0094
    G3 X0.4020 Y0.0960 Z-0.0139 I-0.0036 K-0.0848
    G1 X0.4080 Z-0.0131
     X0.4200 Z-0.0078
     X0.4320
    G3 X0.4560 Y0.0960 Z-0.0315 I-0.0060 K-0.0301
    G1 X0.4680 Z-0.0139
    G3 X0.4800 Y0.0960 Z-0.0072 I0.0180 K-0.0181
    G1 X0.4920
     X0.5100 Z-0.0164
     X0.5220 Z-0.0139
     X0.5400 Z-0.0174
     X0.5520 Z-0.0122
     X0.5640
    G3 X0.5880 Y0.0960 Z-0.0024 I0.0266 K-0.0310
    G3 X0.6060 Y0.0960 Z-0.0087 I-0.0000 K-0.0289
    G1 X0.6180 Z-0.0053
     X0.6300
     X0.6420 Z-0.0104
     X0.6600 Z-0.0099
    G3 X0.6840 Y0.0960 Z-0.0165 I-0.0075 K-0.0746
    G1 X0.6900 Z-0.0147
     X0.7020
     X0.7140 Z-0.0198
    G3 X0.7260 Y0.0960 Z-0.0366 I-0.0180 K-0.0255
    G2 X0.7380 Y0.0960 Z-0.1000 I0.2456 K0.0137
    G1 X0.9540
    F12.0000
    G0 Z0.0120
     X-0.1243 Y0.0480
    F12.0000
    G1 X0.3120
     X0.3180 Z-0.0266
    G3 X0.3300 Y0.0480 Z-0.0164 I0.0240 K-0.0160
    G1 X0.3420 Z-0.0138
    G3 X0.3600 Y0.0480 Z-0.0179 I-0.0023 K-0.0512
    G1 X0.3720 Z-0.0176
     X0.3900 Z-0.0206
    G3 X0.4140 Y0.0480 Z-0.0114 I0.0366 K-0.0592
    G1 X0.4320 Z-0.0124
     X0.4440 Z-0.0102
     X0.4560 Z-0.0105
    G3 X0.4740 Y0.0480 Z-0.0057 I0.0203 K-0.0403
    G3 X0.4980 Y0.0480 Z-0.0191 I-0.0004 K-0.0289
    G1 X0.5100 Z-0.0167
    G3 X0.5280 Y0.0480 Z-0.0207 I-0.0021 K-0.0517
    G1 X0.5460 Z-0.0183
     X0.5580 Z-0.0192
     X0.5700 Z-0.0178
     X0.5820 Z-0.0203
    G3 X0.6120 Y0.0480 Z-0.0006 I0.0313 K-0.0150
    G3 X0.6300 Y0.0480 Z-0.0064 I-0.0000 K-0.0307
    G1 X0.6480 Z-0.0068
    G3 X0.6600 Y0.0480 Z-0.0135 I-0.0060 K-0.0248
    G3 X0.6840 Y0.0480 Z-0.0040 I0.0269 K-0.0327
    G3 X0.7020 Y0.0480 Z-0.0103 I-0.0000 K-0.0289
    G3 X0.7140 Y0.0480 Z-0.0359 I-0.0213 K-0.0256
    G2 X0.7260 Y0.0480 Z-0.1000 I0.5438 K0.0685
    G1 X0.9540
    F12.0000
    G0 Z0.0120
     X-0.1243 Y0.0060
    F12.0000
    G1 X0.3960
     X0.4020 Z-0.0394
    G3 X0.4140 Y0.0060 Z-0.0189 I0.0353 K-0.0069
    G3 X0.4320 Y0.0060 Z-0.0126 I0.0180 K-0.0226
    G1 X0.4440 Z-0.0152
     X0.4620 Z-0.0157
     X0.4740 Z-0.0190
     X0.4860 Z-0.0137
     X0.5040 Z-0.0122
    G3 X0.5340 Y0.0060 Z-0.0335 I-0.0004 K-0.0323
    G3 X0.5460 Y0.0060 Z-0.1000 I-0.3404 K-0.0957
    G1 X0.5640
    G3 X0.5760 Y0.0060 Z-0.0288 I1.4469 K-0.2072
    G1 X0.5820 Z-0.0194
    G3 X0.6000 Y0.0060 Z-0.0120 I0.0180 K-0.0181
    G3 X0.6240 Y0.0060 Z-0.0187 I-0.0042 K-0.0610
    G1 X0.6480 Z-0.0173
     X0.6600 Z-0.0136
    G3 X0.6720 Y0.0060 Z-0.0072 I0.0191 K-0.0213
    G1 X0.6780 Z-0.0065
    G3 X0.7020 Y0.0060 Z-0.0233 I0.0000 K-0.0255
    G1 X0.7080 Z-0.0790
     X0.7140 Z-0.1000
     X0.9540
    G0 Z0.0120
    M2
    Any ideas will be very appreciated ,
    Feb 2007
    711
    That is cool, I haven't tried the image to gcode feature yet..
    As far as the number in red. It looks like your travel is only 6x6x3 inches?
    You program goes outside the limits of your machine.
    All you need to do is jog forward in the axis that will goes outside the limits, and touch off to zero. It looks like your Y axis is going outside the limits though. Try jogging Y to 0.15 then click the touch off button. and enter 0
    that should fix it.
    Apr 2012
    45
    Quote Originally Posted by alan_3301 View Post
    that should fix it.
    Thanks for the information my friend,
    Do you know what's the software in linux for creating PCB ? and convert it to G-code or use from windows, convert to G-code and read on EMC ?
    Oct 2010
    1189
    Use eagle
    Quote Originally Posted by bianchi View Post
    I use pcb-gcode ulp script for eagle simply works
    thomas
  1. X-Axis Stalling with LinuxCNC
    By mrfweet in forum LinuxCNC (formerly EMC2)
    Last Post: 03-18-2012, 10:41 PM
  2. Axis calibration
    By 4lowie in forum Australia, New Zealand Club House
    Last Post: 12-23-2011, 12:50 AM
  3. Axis calibration
    By 4lowie in forum Community Club House
    Last Post: 12-19-2011, 09:48 AM
  4. Axis Calibration
    By davidshearer in forum Tree
    Last Post: 03-10-2010, 04:47 PM
  5. Axis calibration?
    By saabaero in forum Tormach Personal CNC Mill
    Last Post: 06-23-2009, 02:54 PM
