I Have An 87 Amura-seiki Vmc With An 11m. It Has Just The Single Screen For Tool Comp ,length And Radius. My Question Is ,is That Just Way It Is Or Can It Turned On And Off With A Paramerter,or I Am I Missing Some Thing.my Other Question Is If You Generate A Tool Path In Cam Software, Lets Say A 2 Inch Hole With .5 Inch Endmill, And The Software Adjusts For The Tool Radius Do You Set Your Comp To 0 And Then Adjust It,or Should It Generate A 2 Inch Hole With A G41 And .25 Radius Comp.it Doesn't Seem To Be Reading The Radius Comp Any Way. I Can Mill A Circle But Can't Adjust Seem To Adjust It. I 'm New To This Machine And Programming So Any Help Would Be Grear
