587,467 active members*
3,858 visitors online*
IndustryArena Forum > CAD Software > Solidworks > Inkscape .SVG to SolidWorks .DXF
Results 1 to 2 of 2
    Jun 2012
    16
    Ok so I have Downloaded the Inkscape Vector graphics editor for easy logo transfers from .SVG resaved as a .DXF for Solidworks. This method worked for me two times then is failing continuously now.
    Before when I would open the DXF file I would get a black background with white line detail of the graphic as I opened the file in Solidworks. Now I get no graphic and a blank page, even from the old usable graphics files I had success with early on.
    Has anyone used this method and had issues like this as well?
    What would be an alternate to this? Adobe Ilustrater?
    I need to be able to deboss logos on customer products for the machining process.
    Matthew.
    Jun 2008
    562
    Quote Originally Posted by BasuraBlanco View Post
    Matthew.
    Can you post an example and I will see if I get the same results.
    Mike
  1. inkscape to cambam
    By linkintiger in forum CamBam
    Last Post: 09-03-2011, 05:40 PM
  2. how to create code with inkscape
    By dertsap in forum Uncategorised CAM Discussion
    Last Post: 12-28-2010, 10:08 PM
  3. Please Help Me With INKSCAPE
    By diarmaid in forum Uncategorised CAM Discussion
    Last Post: 10-29-2010, 11:47 AM
  4. inkscape to G-code
    By Dan Falck in forum OpenSource Software
    Last Post: 09-13-2010, 01:06 PM
  5. Getting to Lazy Cam from Inkscape
    By John Tribe in forum Uncategorised CAM Discussion
    Last Post: 08-22-2008, 12:04 AM
