587,877 active members*
5,430 visitors online*
Results 1 to 10 of 10
    Aug 2006
    142
    Program Tool Numbers Idea
    We'er a job shop. We can run most parts in several different machines dependent on what's running. The issue with tool numbers is you never know what tool pockets are open. So you end up making extensive program edits. This is risky and time consuming. I got this idea. Make all the "T's" and "H's" macro variables. So all you have to do is plug your tools in whatever pockets are open then just edit the variables at the start of the program. This takes care of all the "H's,"T's" and "T" perps with a single number change. In this example there are (23) tools. For every tool you would need update the tool number "T", length offset number "H" and the tool prep. That makes (69) edits through out this program. Miss an "H" or a "T" you can crash.
    So what do you think? You have a better way? I'd love to hear it.
    Like this:
    O1
    ( FORMAT: FA_450_REV_D_TOOL_MACRO.PST )
    (4" INDEXBLE )
    #101=81(<--- TOOL NUMBER)
    (2.5 TWINBORE )
    #102=92(<--- TOOL NUMBER)
    (5/32 .1562 SOLID CARBIDE DRILL )
    #103=69(<--- TOOL NUMBER)
    (6.2MM .244 SOLID CARBIDE DRILL )
    #104=70(<--- TOOL NUMBER)
    (5/16 .3125 SOLID CARBIDE DRILL )
    #105=66(<--- TOOL NUMBER)
    (11/32 .3437 SOLID CARBIDE DRILL )
    #106=71(<--- TOOL NUMBER)
    (.368 END MILL )
    #107=75(<--- TOOL NUMBER)
    (10.2MM ..4015 SOLID CARBIDE DRILL )
    #108=72(<--- TOOL NUMBER)
    (1/2 .500 SOLID CARBIDE DRILL )
    #109=90(<--- TOOL NUMBER)
    (11/16 .6875 SOLID CARBIDE DRILL )
    #110=88(<--- TOOL NUMBER)
    (3/4 .750 SOLID CARBIDE DRILL )
    #111=82(<--- TOOL NUMBER)
    (.937 ACME SPADE BLADE )
    #112=76(<--- TOOL NUMBER)
    (3/4 .750 SPOT DRILL )
    #113=79(<--- TOOL NUMBER)
    (PRECISION CUTTING TOOL INC. # 30418 FORM TOOL )
    #114=77(<--- TOOL NUMBER)
    (.251 #A-11916 REAMER )
    #115=83(<--- TOOL NUMBER)
    (.379 REAMER )
    #116=94(<--- TOOL NUMBER)
    (3/4-16 SAE PORT /W1.03 CBORE )
    #117=96(<--- TOOL NUMBER)
    (1-1/16-12 SAE PORT )
    #118=91(<--- TOOL NUMBER)
    (3/8-16 TAP )
    #119=80(<--- TOOL NUMBER)
    (M12-1.75 TAP )
    #120=97(<--- TOOL NUMBER)
    (3/4-16 TAP )
    #121=74(<--- TOOL NUMBER)
    (CARMEX MT0375C10 12UN MT7 .375 12 PITCH THREAD MILL )
    #122=99(<--- TOOL NUMBER)
    (90DEG ENGRAVING TOOL )
    #123=21(<--- TOOL NUMBER)
    N1G0G90G10L2P1X0Y0Z0
    N2G0G90G10L2P2X0Y0Z0
    N3G0G90G10L2P3X0Y0Z0
    N4G0G90G10L2P4X0Y0Z0
    N5G0G90G10L2P5X0Y0Z0
    N6G0G90G10L2P6X0Y0Z0
    N7G90G40G20G17G80G94
    N8M82
    N9M16
    N10T#101
    N11M6
    N12M16
    ( OPERATION 1: CONTOUR )
    ( 4" INDEXBLE )
    (B270)
    N14G56G90G0G17X2.38Y4.75B270.S716M3
    N15H#101Z12.
    N16M8
    N17M82
    N18T#102
    N19Z4.5
    N20G1Z4.28F35.8
    N21Y-1.75
    N22G0Z4.5
    ( OPERATION 2: CONTOUR )
    N23G90G0X2.38Y4.75
    N24G1Z4.25F35.8
    N25Y-4.75
    N26G0Z4.5
    N27M9
    N28G91G28Z0.
    N29G28Y0.
    N30M1
    N31M6
    N32M16
    ( OPERATION 3: HOLES )
    ( 2.5 TWINBORE )
    N33G56G90G0X2.38Y0.B270.S800M3
    N34H#102Z12.
    N35M8
    N36M82
    N37T#103
    N38Z4.625
    N39G81G99X2.38Y0.Z3.75R4.625F2.5
    N40G80
    N41M9
    N42G91G28Z0.
    N43G28Y0.
    N44M1
    N45M6
    N46M16
    ( OPERATION 4: HOLES )
    ( 5/32 .1562 SOLID CARBIDE DRILL )
    (B180)
    N47G55G90G0X1.34Y-2.84B180.S4889M3
    N48H#103Z4.
    N49M8
    N50M82
    N51T#104
    N52Z.25
    N53G81G99X1.34Y-2.84Z-.5284R.25F29.33
    N54G80
    N55M9
    N56G91G28Z0.
    N57G28Y0.
    N58M1
    N59M6
    N60M16
    ( OPERATION 5: HOLES )
    ( 6.2MM .244 SOLID CARBIDE DRILL )
    N61G55G90G0X0.Y1.8B180.S3912M3
    N62H#104Z4.
    N63M8
    N64M82
    N65T#105
    N66Z.25
    N67G81G99X0.Y1.8Z-.4864R.25F19.56
    N68G80
    N69M9
    N70G91G28Z0.
    N71G28Y0.
    N72M1
    N73M6
    N74M16
    ( OPERATION 6: HOLES )
    ( 5/16 .3125 SOLID CARBIDE DRILL )
    N75G55G90G0X-2.91Y-2.07B180.S3056M3
    N76H#105Z4.
    N77M8
    N78M82
    N79T#106
    N80Z.25
    N81G81G99X-2.91Y-2.07Z-1.4619R.25F18.34
    N82Y1.9
    N83G80
    ( OPERATION 7: HOLES )
    N84G90G0X2.91Y-2.07
    N85G81G99X2.91Y-2.07Z-1.0269R.25F18.34
    N86Y1.9
    N87X0.Y3.2
    N88Y-3.2
    N89G80
    N90M9
    N91G91G28Z0.
    N92G28Y0.
    N93M1
    N94M6
    N95M16
    ( OPERATION 8: HOLES )
    ( 11/32 .3437 SOLID CARBIDE DRILL )
    N96G55G90G0X-2.31Y-2.13B180.S2594M3
    N97H#106Z4.
    N98M8
    N99M82
    N100T#107
    N101Z.25
    N102G81G99X-2.31Y-2.13Z-.5724R.25F15.57
    N103X2.31Y1.96
    N104G80
    N105M9
    N106G91G28Z0.
    N107G28Y0.
    N108M1
    N109M6
    N110M16
    ( OPERATION 9: HOLES )
    ( .368 END MILL )
    N111G55G90G0X-2.31Y-2.13B180.S2594M3
    N112H#107Z4.
    N113M8
    N114M82
    N115T#108
    N116Z.25
    N117G81G99X-2.31Y-2.13Z-.51R.25F15.57
    N118X2.31Y1.96
    N119G80
    N120M9
    N121G91G28Z0.
    N122G28Y0.
    N123M1
    N124M6
    N125M16
    ( OPERATION 10: HOLES )
    ( 10.2MM ..4015 SOLID CARBIDE DRILL )
    (B270)
    N126G56G90G0X1.38Y1.75B270.S2378M3
    N127H#108Z12.
    N128M8
    N129M82
    N130T#109
    N131Z4.5
    N132G81G99X1.38Y1.75Z2.6294R4.5F23.78
    N133Y-1.75
    N134X3.38
    N135Y1.75
    N136G80
    N137M9
    N138G91G28Z0.
    N139G28Y0.
    N140M1
    N141M6
    N142M16
    ( OPERATION 11: HOLES )
    ( 1/2 .500 SOLID CARBIDE DRILL )
    (B180)
    N143G55G90G0X-1.Y-1.98B180.S1910M3
    N144H#109Z4.
    N145M8
    N146M82
    N147T#110
    N148Z.25
    N149G81G99X-1.Y-1.98Z-.891R.25F15.28
    N150G80
    N151M9
    N152G91G28Z0.
    N153G28Y0.
    N154M1
    N155M6
    N156M16
    ( OPERATION 12: HOLES )
    ( 11/16 .6875 SOLID CARBIDE DRILL )
    N157G55G90G0X1.34Y-2.19B180.S1389M3
    N158H#110Z4.
    N159M8
    N160M82
    N161T#111
    N162Z.25
    N163G81G99X1.34Y-2.19Z-1.3051R.25F16.67
    N164G80
    N165M9
    N166G91G28Z0.
    N167G28Y0.
    N168M1
    N169M6
    N170M16
    ( OPERATION 13: HOLES )
    ( 3/4 .750 SOLID CARBIDE DRILL )
    N171G55G90G0X2.34Y.92B180.S1273M3
    N172H#111Z4.
    N173M8
    N174M82
    N175T#112
    N176Z.25
    N177G81G99X2.34Y.92Z-1.6365R.25F12.73
    N178G80
    N179M9
    N180G91G28Z0.
    N181G28Y0.
    N182M1
    N183M6
    N184M16
    ( OPERATION 14: HOLES )
    ( .937 ACME SPADE BLADE )
    (B90)
    N185G57G90G0X-1.38Y0.B90.S611M3
    N186H#112Z12.
    N187M8
    N188M82
    N189T#113
    N190Z4.0209
    N191G81G99X-1.38Y0.Z2.4244R4.0209F11.61
    N192G80
    N193M9
    N194G91G28Z0.
    N195G28Y0.
    N196M1
    N197M6
    N198M16
    ( OPERATION 15: HOLES )
    ( 3/4 .750 SPOT DRILL )
    (B180)
    N199G55G90G0X-2.31Y-2.13B180.S917M3
    N200H#113Z4.
    N201M8
    N202M82
    N203T#114
    N204Z.25
    N205G81G99X-2.31Y-2.13Z-.1975R.25F9.17
    N206X2.31Y1.96
    N207G80
    ( OPERATION 16: HOLES )
    N208G90G0X-2.91Y-2.07
    N209G81G99X-2.91Y-2.07Z-.1975R.25F9.17
    N210Y1.9
    N211X0.Y3.2
    N212Y-3.2
    N213X2.91Y-2.07
    N214Y1.9
    N215G80
    N216G0Z12.
    ( OPERATION 17: HOLES )
    (B270)
    N217G90G56G0X1.38Y1.75B270.S917M3
    N218H#113Z12.
    N219Z4.5
    N220G81G99X1.38Y1.75Z3.9941R4.5F9.17
    N221Y-1.75
    N222X3.38
    N223Y1.75
    N224G80
    N225M9
    N226G91G28Z0.
    N227G28Y0.
    N228M1
    N229M6
    N230M16
    ( OPERATION 18: HOLES )
    ( PRECISION CUTTING TOOL INC. # 30418 FORM TOOL )
    (B180)
    N231G55G90G0X2.34Y.92B180.S682M3
    N232H#114Z4.
    N233M8
    N234M82
    N235T#115
    N236Z.25
    N237G81G99X2.34Y.92Z-.7R.25F10.23
    N238G80
    N239M9
    N240G91G28Z0.
    N241G28Y0.
    N242M1
    N243M6
    N244M16
    ( OPERATION 19: HOLES )
    ( .251 #A-11916 REAMER )
    N245G55G90G0X0.Y1.8B180.S800M3
    N246H#115Z4.
    N247M8
    N248M82
    N249T#116
    N250Z.25
    N251G81G99X0.Y1.8Z-.439R.25F4.
    N252G80
    N253M9
    N254G91G28Z0.
    N255G28Y0.
    N256M1
    N257M6
    N258M16
    ( OPERATION 20: HOLES )
    ( .379 REAMER )
    N259G55G90G0X-2.31Y-2.13B180.S2023M3
    N260H#116Z4.
    N261M8
    N262M82
    N263T#117
    N264Z.25
    N265G81G99X-2.31Y-2.13Z-.5R.25F24.
    N266X2.31Y1.96
    N267G80
    N268M9
    N269G91G28Z0.
    N270G28Y0.
    N271M1
    N272M6
    N273M16
    ( OPERATION 21: CONTOUR )
    ( 3/4-16 SAE PORT /W1.03 CBORE )
    N274G55G90G0X1.34Y-2.19B180.S1388M3
    N275H#117Z4.
    N276M8
    N277M82
    N278T#118
    N279Z.25
    N280G1F12.5
    N281Z-.8F1.25
    N282Z-.9275F8.34S927
    N283G4P259
    N284G0Z.25
    N285M9
    N286G91G28Z0.
    N287G28Y0.
    N288M1
    N289M6
    N290M16
    ( OPERATION 22: CONTOUR )
    ( 1-1/16-12 SAE PORT )
    (B90)
    N291G57G90G0X-1.38Y0.B90.S975M3
    N292H#118Z12.
    N293M8
    N294M82
    N295T#119
    N296Z4.021
    N297G1F8.7
    N298Z2.744
    N299Z2.595F5.28S578
    N300G4P415
    N301G0Z4.021
    N302M9
    N303G91G28Z0.
    N304G28Y0.
    N305M1
    N306M6
    N307M16
    ( OPERATION 23: HOLES )
    ( 3/8-16 TAP )
    (B180)
    N308G55G90G0X-2.91Y-2.07B180.
    N309H#119Z4.
    N310M8
    N311M82
    N312T#120
    N313Z.25
    N314S202M3
    N315G84.2G95G99X-2.91Y-2.07Z-.92R.25F.0625
    N316Y1.9
    N317X0.Y3.2
    N318Y-3.2
    N319X2.91Y-2.07
    N320Y1.9
    N321G80G94
    N322M9
    N323G91G28Z0.
    N324G28Y0.
    N325M1
    N326M6
    N327M16
    ( OPERATION 24: HOLES )
    ( M12-1.75 TAP )
    (B270)
    N328G56G90G0X1.38Y1.75B270.
    N329H#120Z12.
    N330M8
    N331M82
    N332T#121
    N333Z4.5
    N334S202M3
    N335G84.2G95G99X1.38Y1.75Z2.8922R4.5F.0689
    N336Y-1.75
    N337X3.38
    N338Y1.75
    N339G80G94
    N340M9
    N341G91G28Z0.
    N342G28Y0.
    N343M1
    N344M6
    N345M16
    ( OPERATION 25: HOLES )
    ( 3/4-16 TAP )
    (B180)
    N346G55G90G0X1.34Y-2.19B180.
    N347H#121Z4.
    N348M8
    N349M82
    N350T#122
    N351Z.25
    N352S127M3
    N353G84.2G95G99X1.34Y-2.19Z-.8135R.25F.0625
    N354G80G94
    N355M9
    N356G91G28Z0.
    N357G28Y0.
    N358M1
    N359M6
    N360M16
    ( OPERATION 26: THREADING )
    ( CARMEX MT0375C10 12UN MT7 .375 12 PITCH THREAD MILL )
    (B90)
    N361G57G90G0X-1.38Y0.B90.S3074M3
    N362H#122Z12.
    N363M8
    N364M82
    N365T#123
    N366Z4.021
    N367G91
    N368Z-1.1971
    N369G1X.2505F9.4
    N370G41X.05D0
    N371G3X-.3005Y.3337Z.0201I-.3005J.0316
    N372Z.0833J-.3337
    N373X-.3005Y-.3337Z.0202J-.3021
    N374G40G1X.05
    N375X.2505
    N376G0Z-.1234
    N377G1X.2505
    N378G41X.05
    N379G3X-.3005Y.3438Z.0199I-.3005J.0405
    N380Z.0833J-.3438
    N381X-.3005Y-.3438Z.02J-.3033
    N382G40G1X.05
    N383X.2505
    N384G90G0Z4.021
    N385X-2.38
    N386G91
    N387Z-1.1971
    N388G1X.2505
    N389G41X.05
    N390G3X-.3005Y.3337Z.0201I-.3005J.0316
    N391Z.0833J-.3337
    N392X-.3005Y-.3337Z.0202J-.3021
    N393G40G1X.05
    N394X.2505
    N395G0Z-.1234
    N396G1X.2505
    N397G41X.05
    N398G3X-.3005Y.3438Z.0199I-.3005J.0405
    N399Z.0833J-.3438
    N400X-.3005Y-.3438Z.02J-.3033
    N401G40G1X.05
    N402X.2505
    N403G90G0Z4.021
    N404M9
    N405G91G28Z0.
    N406G28Y0.
    N407M1
    N408M6
    N409M16
    ( OPERATION 27: CONTOUR )
    ( 90DEG ENGRAVING TOOL )
    (B270)
    N410G56G90G0X2.2857Y-1.6786B270.S5000M3
    N411H#123Z12.
    N412M8
    N413M82
    N414T#101
    N415Z4.5
    N416G1Z4.245F10.
    N417X2.3066Y-1.8359
    N418X2.3821Y-1.6856
    N419X2.4577Y-1.8359
    N420X2.4785Y-1.6786
    N421G0Z4.5
    N422M9
    N423G91G28Z0.
    N424G28Y0.
    N425G28Y0X0B0
    N426M01
    N427M70
    N428(TOOL COUNTER SUB CALL)
    N429M98P6082
    N430M30
    "Teach the ignorant, care for the dumb, punish the stupid."
    Jun 2015
    4160
    Re: Program Tool Numbers Idea
    hy indeed, having all edits just near program start, simply saves one time from searching through entire program
    but g-code is ... a thing of the past
    have the software on a tablet, post for specific machine, and select tools though an app
    if needed, consider also to reset N*** at each operation start; for example, operation
    OPERATION 11: HOLES
    not to begin with N143, but N150, thus N144-N149 are no longer to be used
    i have many ideas / kindly
    Ladyhawke - My Delirium, https://www.youtube.com/watch?v=X_bFO1SNRZg
    Aug 2006
    142
    Quote Originally Posted by deadlykitten View Post
    It not just having all the edits at the top of the file. It's that you change one variable per tool instead three per tool down in the program.
    That would require a full time engineer on all 3 shifts and software to support such an adventure.
    OPERATION 11: HOLES
    You search for the variable not the line number.
    Jun 2015
    4160
    It not just having all the edits at the top of the file. It's that you change one variable ..
    i know ...
    i was not refering to your macro, but the way program was created and other uses
    things can be done as to make it easy for all
    Feb 2013
    21
    What control are you using?
    Feb 2013
    21
    In your tool change program you could assign a variable to the tool in the spindle (I chose #148 but it can be what ever works best for your machine). Then for your all your “H's” it would be H#148. This would match whatever tool is in the spindle
    O9001(ATC START M6)
    #1=#4001
    #3=#4003
    #3003=1
    G80M9
    G0G28G91Z0M19
    G0G30G40G91X0Y0
    M6
    #148=#4120
    #3003=0
    (ATC END)
    G#1G#3
    M99
    EX:
    N10T#101
    N11M6
    N12M16
    ( 4" INDEXBLE )
    (B270)
    N15H#148Z12.
    Aug 2006
    142
    Quote Originally Posted by Hardym1 View Post
    O9001(ATC START M6)
    #1=#4001
    #3=#4003
    #3003=1
    G80M9
    G0G28G91Z0M19
    G0G30G40G91X0Y0
    M6
    #148=#4120
    #3003=0
    (ATC END)
    G#1G#3
    M99
    EX:
    N10T#101
    N11M6
    N12M16
    ( 4" INDEXBLE )
    (B270)
    N15H#148Z12.
    Interesting I guess you could use "H#4120" as well.
    I had another idea but the implantation would be far more difficult. We have 120 tool magazines. Many times the tool cut time is less then the time it takes to move the next tool to change position. What if you had a macro that would optimize the part program and the tool order in magazine. It would need to go through the part program and put all the tool numbers in sequential order and then write a temporary tool change program to arrange the magazine in said order. It could be done but you would need a few open pockets to act as buffer pockets to the clear the pockets you wish to use. Then spoof the macro variable of the tool in the spindle so when changed out it goes to the new pocket. The needed logic for such a macro is beyond me. Anyone hear of such a macro?
    https://www.researchgate.net/publica...duplicates.pdf
    https://www.researchgate.net/publica...and_duplicates
    Jun 2015
    4160
    i have a dynamic indexing code, for okuma, considering colision/interference proof ... kind of random within a tolerance/safe distance, autoshifting with offsets
    so a magazine optimization is not that far ...but again, i would code it different, because, even if possible by macro, there are faster ways
    another thing, i could prepare a generalized g-code for such, and it would just need translation to each machine language
    you name it all magazine atributes can be taken into acount
    Aug 2009
    684
    Quote Originally Posted by Species8472 View Post
    Like this:
    O1
    (4" INDEXBLE )
    (2.5 TWINBORE )
    (.368 END MILL )
    (.379 REAMER )
    (3/8-16 TAP )
    (M12-1.75 TAP )
    (3/4-16 TAP )
    N8M82
    N9M16
    N10T#101
    N11M6
    N12M16
    ( 4" INDEXBLE )
    (B270)
    N15H#101Z12.
    N16M8
    N17M82
    N18T#102
    N19Z4.5
    N20G1Z4.28F35.8
    N21Y-1.75
    N22G0Z4.5
    N23G90G0X2.38Y4.75
    N24G1Z4.25F35.8
    N25Y-4.75
    N26G0Z4.5
    N27M9
    N28G91G28Z0.
    N29G28Y0.
    N30M1
    N31M6
    N32M16
    ( 2.5 TWINBORE )
    N34H#102Z12.
    N35M8
    N36M82
    N37T#103
    N38Z4.625
    N40G80
    N41M9
    N42G91G28Z0.
    N43G28Y0.
    N44M1
    N45M6
    N46M16
    (B180)
    N48H#103Z4.
    N49M8
    N50M82
    N51T#104
    N52Z.25
    N54G80
    N55M9
    N56G91G28Z0.
    N57G28Y0.
    N58M1
    N59M6
    N60M16
    N62H#104Z4.
    N63M8
    N64M82
    N65T#105
    N66Z.25
    N68G80
    N69M9
    N70G91G28Z0.
    N71G28Y0.
    N72M1
    N73M6
    N74M16
    N76H#105Z4.
    N77M8
    N78M82
    N79T#106
    N80Z.25
    N82Y1.9
    N83G80
    N84G90G0X2.91Y-2.07
    N86Y1.9
    N87X0.Y3.2
    N88Y-3.2
    N89G80
    N90M9
    N91G91G28Z0.
    N92G28Y0.
    N93M1
    N94M6
    N95M16
    N97H#106Z4.
    N98M8
    N99M82
    N100T#107
    N101Z.25
    N103X2.31Y1.96
    N104G80
    N105M9
    N106G91G28Z0.
    N107G28Y0.
    N108M1
    N109M6
    N110M16
    ( .368 END MILL )
    N112H#107Z4.
    N113M8
    N114M82
    N115T#108
    N116Z.25
    N118X2.31Y1.96
    N119G80
    N120M9
    N121G91G28Z0.
    N122G28Y0.
    N123M1
    N124M6
    N125M16
    (B270)
    N127H#108Z12.
    N128M8
    N129M82
    N130T#109
    N131Z4.5
    N133Y-1.75
    N134X3.38
    N135Y1.75
    N136G80
    N137M9
    N138G91G28Z0.
    N139G28Y0.
    N140M1
    N141M6
    N142M16
    (B180)
    N144H#109Z4.
    N145M8
    N146M82
    N147T#110
    N148Z.25
    N150G80
    N151M9
    N152G91G28Z0.
    N153G28Y0.
    N154M1
    N155M6
    N156M16
    N158H#110Z4.
    N159M8
    N160M82
    N161T#111
    N162Z.25
    N164G80
    N165M9
    N166G91G28Z0.
    N167G28Y0.
    N168M1
    N169M6
    N170M16
    N172H#111Z4.
    N173M8
    N174M82
    N175T#112
    N176Z.25
    N178G80
    N179M9
    N180G91G28Z0.
    N181G28Y0.
    N182M1
    N183M6
    N184M16
    (B90)
    N186H#112Z12.
    N187M8
    N188M82
    N189T#113
    N190Z4.0209
    N192G80
    N193M9
    N194G91G28Z0.
    N195G28Y0.
    N196M1
    N197M6
    N198M16
    (B180)
    N200H#113Z4.
    N201M8
    N202M82
    N203T#114
    N204Z.25
    N206X2.31Y1.96
    N207G80
    N210Y1.9
    N211X0.Y3.2
    N212Y-3.2
    N213X2.91Y-2.07
    N214Y1.9
    N215G80
    N216G0Z12.
    (B270)
    N218H#113Z12.
    N219Z4.5
    N221Y-1.75
    N222X3.38
    N223Y1.75
    N224G80
    N225M9
    N226G91G28Z0.
    N227G28Y0.
    N228M1
    N229M6
    N230M16
    (B180)
    N232H#114Z4.
    N233M8
    N234M82
    N235T#115
    N236Z.25
    N238G80
    N239M9
    N240G91G28Z0.
    N241G28Y0.
    N242M1
    N243M6
    N244M16
    N246H#115Z4.
    N247M8
    N248M82
    N249T#116
    N250Z.25
    N252G80
    N253M9
    N254G91G28Z0.
    N255G28Y0.
    N256M1
    N257M6
    N258M16
    ( .379 REAMER )
    N260H#116Z4.
    N261M8
    N262M82
    N263T#117
    N264Z.25
    N266X2.31Y1.96
    N267G80
    N268M9
    N269G91G28Z0.
    N270G28Y0.
    N271M1
    N272M6
    N273M16
    N275H#117Z4.
    N276M8
    N277M82
    N278T#118
    N279Z.25
    N280G1F12.5
    N281Z-.8F1.25
    N283G4P259
    N284G0Z.25
    N285M9
    N286G91G28Z0.
    N287G28Y0.
    N288M1
    N289M6
    N290M16
    (B90)
    N292H#118Z12.
    N293M8
    N294M82
    N295T#119
    N296Z4.021
    N297G1F8.7
    N298Z2.744
    N299Z2.595F5.28S578
    N300G4P415
    N301G0Z4.021
    N302M9
    N303G91G28Z0.
    N304G28Y0.
    N305M1
    N306M6
    N307M16
    ( 3/8-16 TAP )
    (B180)
    N309H#119Z4.
    N310M8
    N311M82
    N312T#120
    N313Z.25
    N314S202M3
    N316Y1.9
    N317X0.Y3.2
    N318Y-3.2
    N319X2.91Y-2.07
    N320Y1.9
    N321G80G94
    N322M9
    N323G91G28Z0.
    N324G28Y0.
    N325M1
    N326M6
    N327M16
    ( M12-1.75 TAP )
    (B270)
    N329H#120Z12.
    N330M8
    N331M82
    N332T#121
    N333Z4.5
    N334S202M3
    N336Y-1.75
    N337X3.38
    N338Y1.75
    N339G80G94
    N340M9
    N341G91G28Z0.
    N342G28Y0.
    N343M1
    N344M6
    N345M16
    ( 3/4-16 TAP )
    (B180)
    N347H#121Z4.
    N348M8
    N349M82
    N350T#122
    N351Z.25
    N352S127M3
    N354G80G94
    N355M9
    N356G91G28Z0.
    N357G28Y0.
    N358M1
    N359M6
    N360M16
    (B90)
    N362H#122Z12.
    N363M8
    N364M82
    N365T#123
    N366Z4.021
    N367G91
    N368Z-1.1971
    N369G1X.2505F9.4
    N370G41X.05D0
    N372Z.0833J-.3337
    N374G40G1X.05
    N375X.2505
    N376G0Z-.1234
    N377G1X.2505
    N378G41X.05
    N380Z.0833J-.3438
    N382G40G1X.05
    N383X.2505
    N384G90G0Z4.021
    N385X-2.38
    N386G91
    N387Z-1.1971
    N388G1X.2505
    N389G41X.05
    N391Z.0833J-.3337
    N393G40G1X.05
    N394X.2505
    N395G0Z-.1234
    N396G1X.2505
    N397G41X.05
    N399Z.0833J-.3438
    N401G40G1X.05
    N402X.2505
    N403G90G0Z4.021
    N404M9
    N405G91G28Z0.
    N406G28Y0.
    N407M1
    N408M6
    N409M16
    (B270)
    N411H#123Z12.
    N412M8
    N413M82
    N414T#101
    N415Z4.5
    N416G1Z4.245F10.
    N417X2.3066Y-1.8359
    N418X2.3821Y-1.6856
    N419X2.4577Y-1.8359
    N420X2.4785Y-1.6786
    N421G0Z4.5
    N422M9
    N423G91G28Z0.
    N424G28Y0.
    N425G28Y0X0B0
    N426M01
    N427M70
    N429M98P6082
    N430M30
    Hi, did similar method to save the hassle of swapping tools or messing with programs, works well on multi pallet machines running various operations. Even applied it to work offsets to allow corresponding pallet to load without having to edit anything else. Only difference was our programs were kept in separate folders and each main program had a sub to store the list of variables.
    DP
    Jun 2015
    4160
    hello as to make it more general, this is only a part of linking different machines with outside preset tooling, so another aspect to consider are offsets zero shifts between machines and external measuring equipment, etc
    all these have been solved decades ago
    another thing to automate, is to generate tool setter cycles only for last tools to get in the magazine ...
    i can help for actual okuma controls, while for others i need help from someone that knows that machine / kindly
    Jun 2015
    4160
    hello rencetly, i tooked a look through all my posts, and i found a thread on faster tool measuring and program asignemnt for okuma.
    it was develop as to detect new mounted tools, execute measurement on last modified magazine posts, and change a orogram file accrodingly
    so i remembered this thread, and i come back to present a time line :
    ... 2013: laying my hands on the 1st cnc, okuma lathe
    ... 2016: 1st encounter with okuma mill
    ... 2017: developed macros and software, to solve such issues related to tool numbers for okuma
    ... 2019covid : i was in the situation to give a test as an operator for a haas, and i told the programmer that there are faster ways to pair the program with the machine magazine, and i can help, because there is too much time waste scrolling through the haas controller, well, through any other controller for that reason
    solution involves identification of operations from program file, presenting the operator with a table prompt, where he has to assign the magazine pots, then repost the entire file, and load to machine
    for a shop with local network, this can be done after the files reached the machine, like in case when the program was created at 10am, but loaded at 2nd shift
    if no local network, then a device with remote conection to the main pc, can be used before creating the file, so the operator to input data, then create the file, then have it ready for loading to the machine, consideing he knows how to load programs into the cnc
    such methods can be implemented safe, and deliver faster times than panel/macro operation / kindly
  1. Replies: 5
    Last Post: 01-29-2020, 01:39 AM
  2. need to renumber program o-numbers and subs
    By cuttooltx in forum Uncategorised CAM Discussion
    Last Post: 11-27-2013, 10:59 PM
  3. Fanuc 11M program numbers
    By rick kroeze in forum Fanuc
    Last Post: 04-21-2012, 02:36 PM
  4. 0MC more program numbers
    By salmve in forum Fanuc
    Last Post: 07-16-2011, 12:27 PM
  5. Fade-out of program numbers 900…
    By Jasper0815 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-02-2008, 07:28 PM
