587,714 active members*
5,033 visitors online*
Thread: anvil
Results 1 to 3 of 3
    Dec 2011
    anvil
    Hello guys,
    is it good idea to try to make an anvil for my workshop from epoxy granite composite with hardened steel way on top? :cheers:
    Apr 2004
    5750
    I don't think so
    Don't they have real anvils over there? Even blacksmiths who make everything themselves don't often try to make their own anvils. And anvils aren't made that way. For one thing, epoxy doesn't do well with heat, so when you lay red-hot iron on the top, it will soften and release the top plate, especially when you start pounding on it.
    A better idea, if anvils are really unavailable there, would be to use a section of railroad rail; it won't make a full-sized anvil, but it's generally good steel, and will work for some purposes.
    Andrew Werby
    ComputerSculpture.com — Home Page for Discount Hardware & Software
    May 2010
    307
    As Andrew said, heat would be a problem. From what I've read, epoxy granite does not deal well with impact forces either.
  1. Looking for blacksmith hitting anvil image
    By salambert6 in forum Want To Buy...Need help!
    Last Post: 02-17-2010, 07:15 PM
