Total newbie here and I need help wiring this 4 axis motion controller to 2 (for now) stepper motor drivers TIA
Hi Evo - The driver will come with a wiring diagram. I could guess at the controller connections and the website does not exist so no support. I'd bin the SEEKU controller and get one with support such as:
https://www.cnc3d.com.au/nighthawk-s...cnc-controller or
https://www.cnc3d.com.au/nighthawkcnc-controller These are much easier to set up for a newbie and perform very well.
The drivers can be used by either of above or sell the drivers and use the Knighthawk in a one box solution. I have built a few multipart control systems (and blown up controllers & BOBs in the process) and now use the Knighthawk all in one box solution. Same cost and easy, reliable with warrantee build & excellent support... Good Luck on your build Peter
edit - depending on what you want to do I have found that 24V systems are marginal if you need speed. 36V or 48V or even higher is much better and does not cost anymore. The driver you have is rated at 40V for instance so go at 36V much better then 24V...
Thanks, yea not finding any support on the controller I understand the direction +/- and pulse +/- just not sure where the enable +/- out of the controller are located
eenee meaneee miny mow - pick a number and make smoke! Peter
lol not what I want too do
