587,534 active members*
3,512 visitors online*
Results 1 to 7 of 7
    Jan 2011
    9
    Supplier of IR laser goggles?
    1. Can anyone recommend a European supplier of goggles for 9229-9317nm and 10200-10800nm IR lasers?
    2. Many of the desktop laser cutters have a transparent window in the top and operators don't have to wear goggles. What material is the window made of for IR?
    Many thanks.
    Mar 2012
    112
    The windows are typically either acrylic/perspex/plexiglas, polycarbonate or glass, all of which are great at absorbing the 10.6um CO2 laser wavelength. Regular polycarbonate safety goggles are usually sufficient for lower powered machines (<100W).
    Build logs and other projects of mine: http://nqlasers.com/
    Jan 2011
    9
    OK. Thanks.
    Jan 2007
    723
    How thick should an acrylic window be for an 80w laser?
    http://www.glenspeymillworks.com Techno LC4896 - 2.2Kw Water Cooled Spindle | Moving Table Mill from Omis 3 CMM, 500Lb granite base | Epilog Legend 32 Laser Engraver
    Feb 2009
    6028
    You sure you don't have an extra 0 in those numbers?
    And lexan won't protect your eyes, it may reduce power, but 1 watt getting through will pop them like a grape. Laser rated Is the only way to go.
    Oct 2011
    155
    Sorry if this is a bit late:
    New HQ CE CO2 Laser Safety Goggles Protection Glasses 10600nm 10.6um | eBay
    I am NOT associated with these guys, I HAVE bought spare mirrors, lenses and laser tubes from them without any problems. They post the same day and package well.....
    Mar 2012
    112
    No, not missing any 0's. I have personally tested a few cheap hardware safety goggles, and with a 40W laser, it took a bit over 16 seconds to fully punch through. I have a laser power meter on the other side, and there is no light at all seeping through until it finally punches through, they are more than adequate.
  1. What goggles/glasses for a laser?
    By marcocp91 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-24-2012, 12:20 PM
  2. reviews of laser protective glasses and goggles?
    By shatterjack in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-30-2012, 02:38 AM
  3. Laser Safety glasses/goggles
    By Scott Riddle in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-28-2010, 06:13 PM
  4. LASER UK SUPPLIER
    By shellglen69 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-01-2009, 01:08 AM
  5. Gas supplier in UK for co2 laser ?
    By greybeard in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-24-2006, 01:49 PM
