587,782 active members*
2,713 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Controller Cards > NVCM breakout board inputs not reading in mach 3
Results 1 to 5 of 5
    I've got a NVCM6v2.1 breakout board and I'm unable to get any of the inputs to read into mach 3. The wiring for the inputs seems pretty straight forward. I've got the spindle, steppers, and coolant valve output all working correctly, but I can't get any inputs to read into mach 3. If I go to the diagnostics tab, I can see all the outputs firing, and the corresponding axis, spindle, and valves fire, but none of the inputs will read when the sensors are triggered or the input is simply jumped to ground bypassing the switch.
    I've set them enabled, on port 1, with the correct pin numbers, not emulated, with hotkey 0. The inputs I'm using are overtravel switches on each axis(x,y,z,a) and an e-stop button. They're all wired nc and are simple contacts. Do they need a resistor or something not shown in the wiring diagram? Is there some trick beyond the wiring and configuration settings in the manual you need to do to get these to work?
    I've tried two different brand new nvcm boards and they both behave the same. Steppers and outputs both work fine, and inputs won't read at all.
    Anyone have any insight?
    Thanks,
    Nov 2013
    4551
    Re: NVCM breakout board inputs not reading in mach 3
    that manufacturer has been permanently banned from the Mach forum for peddling pirate copies of Mach. Good luck.
    Craig
    Mar 2019
    3
    Realize this is an old thread, but I take it that your inputs are limit switches. I have the NVCMVv2.1 and used simple NO button switches and they work. Had to play with pin # to get it to match MACH3. still working on Spindle controls.
    This unit cannot process the input signals in real-time, so input signals may not be that useful anyway.
    Quote Originally Posted by cjrn View Post
    What pin# did you use...? Having same problem...none of inputs work...
    Apr 2022
    140
    It was working fine for me when I used it.
    You mention using NC switch.
    Have you try NO contacts or change active high instead low? It has optocouplers on the input but then it depends on software…
    One never know how they programmed it.
    I’ve set it trough NO contacts active low on the pins and ports as in the manual and all work fine…
  1. Mach 3 breakout board
    By MAHNKEN in forum CNC Machine Related Electronics
    Last Post: 02-04-2021, 10:33 AM
  2. Need help, Mach 3 breakout board upgrade!!
    By Wgarner1414 in forum CNC Machine Related Electronics
    Last Post: 05-03-2016, 05:58 PM
  3. I need 6 inputs, but my breakout board has only 5, how?
    By lucky021 in forum Canadian Club House
    Last Post: 06-13-2010, 09:28 PM
  4. breakout board suggestions for mach and lathe
    By panaceabea in forum Mach Lathe
    Last Post: 12-15-2007, 10:20 PM
