587,905 active members*
3,084 visitors online*
IndustryArena Forum > CNC Electronics > Leadshine > Leadshine EL5 - I need copy all configuration from a working Servo Driver to a New
Results 1 to 3 of 3
    May 2024
    2
    Unhappy Leadshine EL5 - I need copy all configuration from a working Servo Driver to a New
    Hi there,
    So, we work with Solvent Printers, Flora LJ320K and my Servo Driver died, I bought from a guy, a used piece, from another Printer brand, the Model is EL5-750 (ACH750), I already puuted all Parameters by HMI Panel, but still breaking and doing JOG error, I tried find the correct version of ProTuner, but without sucess, if someone can help I'll be gratefull
    I have no idea how a can copy all parameters from the Working Server Driver, because I have another printer with the same Servo Driver and working well
    thanks in advance
    Re: Leadshine EL5 - I need copy all configuration from a working Servo Driver to a Ne
    Some drivers need to do EE-DEF procedure after replacing a new AC servo driver
    Step 1: PA0=385
    Step 2: PA1 change to match the motor
    Step 3: Find EE-DEF, press the ENTER key and hold 3 seconds
    But not sure if your EL5-750 (ACH750) need to do the same or not.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    May 2024
    2
    Thanks, but don't worked
    perhaps just connecting but cable, but, again I have no solution, I can't find the corret version of ProTuner to do it
  1. Replies: 15
    Last Post: 01-09-2024, 03:50 AM
  2. Replies: 7
    Last Post: 04-10-2020, 07:34 AM
  3. Leadshine servo driver tuning
    By Xienix in forum Leadshine
    Last Post: 07-27-2018, 10:28 PM
  4. Leadshine EL5 servo drive in torque mode
    By durundal in forum Leadshine
    Last Post: 05-17-2017, 01:22 PM
  5. Replies: 6
    Last Post: 11-20-2015, 07:11 PM
