587,374 active members*
3,329 visitors online*
Results 1 to 3 of 3
    Jan 2009
    40
    Tool unclamp noise
    Hello.
    I have a problem whit the toolchange in a MA40HA. It seems like the tool is not unclamped fast enough. The arm sometimes drags the tool out from the spindle whit a banging noise. I have taken the cylinders apart and checked the springs and the draw bar. It did not help. I bleeded the system and there seems to be no air in the hydraulic oil. The problem is present even whit a low tool change speed (25%).
    Are anybody having a idea what the cause could be?
    Could the hydraulic valve work too slow?
    Thanks for any help!
    Best regards, Samuel
    Apr 2024
    4
    Re: Tool unclamp noise
    Call a engineer, some of the MA40H has 2 stage unclamp cylinder, and a some of them has really difficult hydraulic system..
    also inside drawbar there a some ruller pins, that rust.
    My suggestion if yu are not sure about the mechanical parts then call local service.
    Oct 2009
    119
    Check the two collets loose. First unclamp and then use collet fixing tool.
  1. Tool unclamp / drawbar sensor
    By mishikwest in forum Haas Mills
    Last Post: 01-30-2021, 01:34 AM
  2. Spindle Tool Unclamp Timeout
    By Ph2011 in forum Bridgeport / Hardinge Mills
    Last Post: 10-19-2012, 01:57 PM
  3. mazatrol tool unclamp
    By bigbobr in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-04-2012, 02:48 PM
  4. Tool clamp/unclamp via Focas
    By Danijel in forum Fanuc
    Last Post: 01-14-2011, 08:43 AM
  5. Tool unclamp fault
    By IMlearnin in forum Daewoo/Doosan
    Last Post: 06-08-2007, 02:40 AM
