The difference between the oscillating knife and the fiber cutting edge of the laser machine:
An oscillating knife is a device that uses high-frequency oscillation to cut materials.
The cutting principle is to use the high-frequency oscillation of the blade to generate friction between the blade and the material, thereby cutting the material.
When cutting fabric with an oscillating knife, the oscillation of the blade will pull the fabric, so threads may easily come out from the edge of the fabric.
Filament at the edge of the fabric means that the fibers at the edge of the fabric fall off due to cutting, forming a filament-like substance.
Silking at the edge of the fabric will affect the appearance and quality of the fabric, so it needs to be avoided as much as possible.
When cutting fabric with an oscillating knife, the following methods can be used to reduce the yarn coming out from the edge of the fabric:
Use a sharp blade. A dull blade will cause more pulling on the fabric, making it easier for threads to come out.
Reduce the cutting speed appropriately. Excessively high cutting speed will increase the friction between the blade and the fabric, making it easier for wires to come out.
Use appropriate pressure when cutting. Excessive pressure will deform the fabric and more easily lead to threading.
laser machine
A laser machine is a device that uses laser light to cut materials.
The cutting principle is to use the high energy density of the laser to instantly vaporize the material, thereby cutting the material.
When a laser machine cuts fabric, since the laser does not pull the fabric, there will be no threads coming out of the edge of the fabric.
The edge of the fabric cut by the laser machine is smooth and flat, and there will be no burrs or silk.Choose digital knife or laser tips :
oscillating knife popular reason in the market ,
1 Cutting mutli layer ,laser is main for single layer
2 digital knife cutting without smoking ,laser cutting have smoking , better for worker health ,
3 some times ,laser maybe cause fire .
4 laser tube normally work 8000 to 10000 hours ,there is power nature loose . digital knife cnc just change blade .
5 Some prevent burning fabrics cannot be cut by laser machines
5 type popular Fabric solution
Solution 1
Multi layer cutting with auto loading ,unloading ,Automatic cloth spreading machine
Spreader pull fabric many layer till thickness rough 100mm, digital knife cnc one times cut many layer .
Spreader machine work for multi layer fabirc
https://youtu.be/Ems54uiCkks
100mm thickness fabric layer cutting samples show
https://youtube.com/shorts/lhf_OP-qeNE
Solution 2
You want multi layer and also want control budget .
Worker manual pull fabric for many layer on digital knife cnc table , use pneumatic knife to cut .
pneumatic knife cutting multi layer fabric
https://youtu.be/OSYFg1wSRAQ
Solution 3
You want multi layer and also want control budget with EOT 400w cutting head .
Solution 4 ,single layer cutting
Single layer auto loading cutting with rotary knife head
auto loading motor type digital knife cnc
https://youtu.be/9Z_oZUaKQY0
https://youtu.be/BoiJAYVRrvk
Simple roller for auto loading
https://youtu.be/IUDHG9VGyYw
Solution 5
Single layer auto laoding with double gantry , each gantry with 1 pcs CO2 laser head
double gantry CO2 laser cutting fabric
https://youtu.be/DUrRdtv1hY0
Solution 6
1626 fabric laser machine:
https://youtu.be/j9FzQLHbMcM
Kindly contact with me about your advice about fabric cutting solution . my email is [email protected] or whatsapp +8618560201508
