If I try to use station T330 in our Vipros 2510C I get a shotpin error followed by a WDT error.
With the turret table rotating clockwise our turret has :
T328
T229
T330
T231
I am trying to troubleshoot this issue with a very simple program like this (Press select keyswitch is turned to OFF to avoid punching)
G90;
X2400. Y1100. T328;
G50;
G90;
X2400. Y1100. T229;
G50;
G90;
X2400. Y1100. T231;
G50;
All these small programs work fine.
However if I try to use station 330 the station turns, stops at where station 330 is supposed to be, tries to insert the shotpins and fails, and I get:
1080 SHOTPIN(ON) UPPER(IN) LS
1081 SHOTPIN(ON) LOWER(IN) LS
and after a few seconds:
NO 2039 W.DOG TIMER(TF TURRET)
If I turn to manual mode, clear the error and move the turret somewhere else, I can still run i.e
G90;
X2400. Y1100. T328;
G50;
So actually, the reference is not lost, and I could go ahead and run a program that does not use station 330.
I also tried manual mode and could find where the station 330 is (wrongly) detected, somewhere near station 208/309. I attach a picture where the real and the wrong position are sensed.
So actually the question is: how is station position determined or sensed ?
