587,517 active members*
3,406 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > Open Source Controller Boards > Open Source Boards Available, Stepper Drivers and Break Out Boards
Page 39 of 39 29373839
Results 761 to 763 of 763
  1. #761
    Feb 2007
    4
    Quote Originally Posted by pminmo View Post
    If you look at what the LM317 runs, it's the 5V on the board. The incomming unregulated VDC (18V or more) is used for the H bridge of the motor in the L298.
    Thanks again for the feedback PMinMO. Clearly I am not understanding the circuit well at all. I'll go back and take another look at it and figure it out.
    Wayne
  2. #762
    Jul 2011
    0
    Help me! i want to try with Tach's 3axis board(driver and choper) but i have problem!!!
    can i change irlz44 as irf540? and i can't buy IRF9540 in my place,help me to find out IC same as to change it.
    Thanks so much!!!!
  3. #763
    Jul 2017
    57
    Re: Open Source Boards Available, Stepper Drivers and Break Out Boards
    Does anyone know why I would be able to run my Steppers with TB6600 Drivers and a DM542T Driver, but not with my gecko 201x driver on Mach 3? All I’m getting is stuttering or the motor only moving in one direction. When it’s energized with the driver, it is possible to turn the shaft manually easier than usual.
  1. Best break out boards?
    By Nigel Tufnel in forum Stepper Motors / Drives
    Last Post: 12-27-2013, 07:12 PM
  2. Dual Break out boards
    By ynnek in forum DIY CNC Router Table Machines
    Last Post: 07-11-2013, 04:34 PM
  3. Break out boards...
    By kiwichris in forum LinuxCNC (formerly EMC2)
    Last Post: 11-06-2012, 10:20 PM
  4. Servos, drivers, break out boards
    By HereinCS in forum Servo Motors / Drives
    Last Post: 08-13-2010, 06:09 PM
  5. PC parallel port break-out boards
    By widgitmaster in forum CNC Machine Related Electronics
    Last Post: 09-20-2005, 01:47 PM
